just wondering are you guys disconnecting the 2 stage boost control thing the R33 has??? you know its 5psi in the lower rpm ranges then goes to 7psi in the higher ranges?? If you got it set at 10psi then spikes to 12 it may be due to this factor. Just something that I thought would be worthwhile to mention :)
  • Replies 1.8k
Posted Images
HI,
Mark here...
It's worth mentioning that sometimes when I get an email requesting details for purchase, my responses just bounce back repeatedly and there is nothing I can do... :(
And then a couple of times that guy has left a message on this forum about getting no response... :blink:
Also just a reminder that I 'rarely' check pm's so if you send me one and get no response..then you why...and I see i have a stack of them...
I work out of town too so sometimes I can get a bit behind qwith emails and post outs...
Also, sometimes my part supplier can be unable to get an essential part and there can be delays..especially with springs and the one I use can't be substituted without making a crap controller...Whatever the delay if there is one is usually for a good reason and not just coz I'm slack.. Im actually as busy as twins :(
Cheers
Mark
[email protected]
I jsut installed mine today. very impressed. With R33 theres a T piece, you remove this, you block the hose coming from the solaniod with a bolt. and from the waste gate you just plug into the controller like the pic supplied, and the other into the hose coming out of the pipe.
Yes it works :yes:
Another tip; hot water before you start on the rubber hoses loosens them up :cheers:
Ordered mine 7 days ago, How long does it take to get to Perth?
hope it comes soon :)
I would have brought one but the guy has never answered my questions of wether I can pick it up or not.......and the price has jumped to $34.90.....so I know what he can do with his boost controller.......
I got my Boost Controller today. Took a few days but came in perfect condition and with good instructions. Just waiting for my Boost Gauge now.
How long can the tubes be if you extend them to mount the controller somewhere?
tubes can be as long as you need them to be, but the shorter the pipes the better the response from the boost controller.
I am a noob. Wanting to buy this for my stock 33 turbo. I notice that the car is meant to be hitting i think 7psi standard but rarely hits it, more like 5-6. Will getting this and say putting it to 8psi or something mean that it will hit 8psi all the time (when on full boost). Cheers. Also what is the max for safest and most reliable operation for the 33 gts-t. I am only looking to maintain a good level of boost instead of constantly getting below tha standard
stock boost gauge isnt in PSI its in MMHG and 7X100 MMHG is about 13.5/14 PSI (cant remember which exactly) You can individually adjust this controller, yes but you should invest in a boost gauge that reads in psi or bar first, because these will be more accurate and quite a bit easier to figure out, going by what other people are running. As for stock boost, im not sure but try running a search with "Safe BOOST R33" or something
Edited by r32 gts-turbo
just wondering are you guys disconnecting the 2 stage boost control thing the R33 has??? you know its 5psi in the lower rpm ranges then goes to 7psi in the higher ranges?? If you got it set at 10psi then spikes to 12 it may be due to this factor. Just something that I thought would be worthwhile to mention ;)
I thought by adding this boost controller, the two stage boost control no longer came into effect?
Can any1 show me is there any thread to teach how to install a manual boost controller?Best if wif pics...i cant find any...i just bought 1 through ebay,...i think is quite similar or totally the same wif this 1~thankx~
I dont see how hard it could be to install..
One end goes to positive boost pressure, ie inlet / ic piping
Other end goes to Wastegate actuator
of cause i could be wrong, thats how my current setup works
ive just payed for 2 of these bad boys last night (me and a mate)
hopefully give me more control over the boost
/Happy
Edited by Unkn0wn
Is this kit the Turbo tech boost controller on Ebay for $34?
Im pretty keen to get one as im getting my bosch 044 next week and my FMIC soon so ill feel comfortable running about 10.
cheers
also, i just order one of the gktech intercoolers from the group buy, would these coolers have the nipple on the ic piping where the stock one is? or would i have to get a nipple welded to the new ic piping?
another thing to addm is how exactly can this magical boost controller increase spool time?
are you sure its not the placeboi affect?
im all for trying it but im curious as to how this boost controller can reduce lag and increase spool time.
Edited by hayden49
What happens on a tradional bleeder or stock setup, is that the wastegate actuator sees a signal all the time so may trigger the wastegate to start opening early. Now what this controller does, is stop the signal from getting through to the acuator until it reaches a set point. Because the actuator dosen't get a signal, it leaves the wastegate firmly shut until the actuator sees a signal at which time it triggers the wastegate to open fully. Hense the super fast spool up.
This is a similar concept to what some EBCs can be setup to do, but dosen't have the high price tag to go with it.
An inexpensive product that actually does what it claims....took me 2 min to install with great results. Even if it did take a week to get here, it's $35 well spent. Nice one Mark cheers....
Hello Fellow Members
I just spoke to jrdsports about organising a group buy for us members on there boost controller.
He said if we can get 15+ people he will do them for $22 shipped.
Ill Start im getting 2 for freinds cars.
jrdsports said members should use reference SAU.
LINK
http://cgi.ebay.com.au/JRD-Boost-Controlle...1QQcmdZViewItem
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
