  • Replies 1.8k
Posted Images
pm sent, interested in getting one of these badboys !
Who did you send the pm to?
if it was simark87 then he probably won't see it cos he hasn't been here since 19th July, 2006 - 08:23 AM.
If you want one, they're on ebay under turbotech.
Dammit - lol - I just sent him a PM too!
I just sent him an email post number 52 says we can get them for $28 delivered, so I was just asking him about that not sure if he still uses that e-mail though.
I'll let you know if/when he gets to me if thats still the case for SkylinesAustralia members.
[email protected] is his correct address.
They cost $37 delivered now.
hey all, since everyone seems to have drilled a hole in theirs, i went ahead and drilled mine as well. Not sure if its a little to big or not but it definately spools a whole lot faster.
Anyway what happens if the hole is too big?
And since the hole is letting boost get out to keep the wastegate shut, wouldnt that mean my turbo is working harder to create the same amount of pressure then if it wasnt drilled?
The hole is there to bleed the pressure between the actuator and the ball ONLY once the boost pressure drops to prevent the wastegate from staying open. due to the ball/hose/acutator creating a pressure vessel.
The downside to this is the hole will bleed boost like a traditional bleeder and as it tapers off at high RPM the boost will also drop off and make the controller less accurate.
This also means as some boost is bleeding off it would keep the actuator shut for a few 100ths of a second more. but would not make a difference in spool time.
My personal opinion is that the hole is not needed as it was in the original design and has since been dropped. I have used both and currently have the one without the hole and it holds a dead flat line for boost.
i was using mine with no hole too. it held boost great. had it on the dyno, showed a steady 10psi all the way till the end, then dropped slightly by less than 0.5psi. then i discovered i had a boost controller module connected to my unichip :D so i removed the turbotech, hooked the stock solenoid back up. set it to 10psi on the dyno, and it held the exact same boost pattern. needless to say, the turbotech was doing an excellent job. the only difference being, once i was back on the road, i discovered that the very slight lag on changes was now gone.
edit: also, one less defect in the engine bay :(
Edited by Munkyb0y
well it seems hes not selling them nemore coz theres no listing on ebay for them
i want to get myself another one coz i might have over drilled this one
I bought one 2 weeks ago.
Just did a quick search then and the item is still for sale?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...s_promot_widget
between 1 and 1.5 the hole needs to be if you drill.
are these the same as the jrd ones? on ebay???
i got one for my mate on his 180 and its bieng a pain in the ass. keeps spiking sometimes.
i noticed the spring inside is shit and gets bent and stuck. it this causing my boost spike problems?
and the difference between the two is?
we got a cooler on his lastnite and just plugged it all back up standard so its holding 9pound fine without that pain in the assssssss controler!
Edited by Angus Smart
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
