cool? it's a pain in the a$$. My GTR has this chime, but thank f**k the previous owner 'tried' to disable it so it only works intermitently and when it does work it's muffled. the strange thing is it never used to activate when I was using my kakimoto ecu, when I put the power FC in I noticed it straight away, possibly just a coincidence though. I say get rid of it as soon as is possible.
https://www.sau.com.au/forums/topic/73759-100-kpmh-chime/#findComment-1354200
Its up under the kick where your left knee is. Smallish black box say 2-3inchs by 3-4 inches. Just unplug it, go for a drive. If its the door one, PUT IT BACK, it can play up with your central locking etc if its the door/left the lights on beep one.
https://www.sau.com.au/forums/topic/73759-100-kpmh-chime/#findComment-1354934
Holy crap I didnt know that Cefiros had this and lately I could have sworn that I could hear the faintest chiming noise in the car. I have no stereo yet so I wont be able to here mine once thats in :D
Thanks for pointing out that they have these.
https://www.sau.com.au/forums/topic/73759-100-kpmh-chime/#findComment-1354953
yer that thing drives me insane.. i also changed ecu's and it went away but guess what... its back! smallish black box you say?... that little f%#k is dead tomorrow!
There is about 3 of them tho. So just unplug them one by one first. From memory it was the far left one. But I took mine out well over a year ago, so I really cant remember.
https://www.sau.com.au/forums/topic/73759-100-kpmh-chime/#findComment-1355211
My gawd I thought it was something wrong with my speedo or something. I had a suspicion that it was a speed warning as it always comes on at the same speed - a ticking sound - but it seems inconsistent - seems to have stopped now.
Kills you when driving long distance in 110k zones - just have to turn up the stereo.
https://www.sau.com.au/forums/topic/73759-100-kpmh-chime/#findComment-1355367
Yeah its the furthest to the left. Just stick your head under there and you can see it. Really simple to remove. Removed mine 2 weeks ago.
You guys are lucky. On the 32's its located directly behind the instrument cluster. You have to dismantle the dash to get to it so you can snip the wire.
When your looking for the cef one, if you remove the door/light chime you will this will affect your alarm/central locking (if you got it) the only way to over come this is to wire them into each other so you still have a closed circuit. But this will eliminate your warnings by doing this.
:P
https://www.sau.com.au/forums/topic/73759-100-kpmh-chime/#findComment-1357725
LoL. Dude TRUST me it is still there. Easy way to tell, when you go to sleep, do you hear this DING, DING, DING and see 110kmh on a circle when your dreaming?
https://www.sau.com.au/forums/topic/73759-100-kpmh-chime/#findComment-1357754
    • The front prop shaft from my GTR had very notchy unis, which obviously needed replacement but unfortunately uses the (usually) non-replaceable (staked) type.     A new shaft is something like $2K plus shipping from Japan.   I wouldn't even bother asking the local Nissan spares dept.     Rang Hardy Spicer but no go, which surprised me a little.     There's a place over Dandenong way that would make me a 'performance' shaft but un-necessary in my situation.   They claimed to be getting the equipment in to replace staked unis but couldn't give me a timeframe.   Anyway, long story short, found a place to do the work just 5 mins from me: https://knoxdriveshafts.com.au $420 (cash) and about a week later I have my driveshaft back.   Price includes balancing. Owner is a one man band working out of a shed in his backyard but from what I could see he's very well setup with some expensive equipment.
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
    • oops that seems much easier lol.
    • Are you using the factory rail?  Is there any reason you don't want to use one of the two you already have, they don't have to attach to the fuel rail directly.  If you 100% must have a FPR that directly bolts to the fuel rail, you could get a Radium setup. I use a radium fuel rail and the direct mount regulator, it is quite a sexy setup.
    • https://www.google.com/search?q=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&sca_esv=6710113de42d5150&source=hp&ei=GhPbaNHfNZeinesPyPqEiQc&iflsig=AOw8s4IAAAAAaNshKnLkjQGMWYT5EyclmXEJm8ZXSWDb&ved=0ahUKEwjR1JOCjf-PAxUXUWcHHUg9IXEQ4dUDCCE&uact=5&oq=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&gs_lp=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_EFhqEHecdnjv2SBwYyLjU1LjGgB7XnArIHBjAuNTUuMbgH4UXCBwgwLjUuNTEuMsgHiQI&sclient=gws-wiz
