since i cant offord big flash new brakes i decided to dress up my crappy old calipers, i went and bought some dupli-color, metalcast anodized paint, i selected blue took it to the counter and the guy told me i needed the proper primer for it, i thought he was just tryin to scam me, but you do actuly need it to create the shinny reflective anodized look, i painted them and they turned out really good since my rim's have already got anodized blue in them they matched really trick, it is heat proof specificly for calipers and rocker covers ect ect, im gona do my valve cover also so ill let yas know how it turns out, but its really goot for dressin those dull parts up,
https://www.sau.com.au/forums/topic/73794-how-to-anodize-your-brake-calipers/
  • Replies 182
that looks cool! You did a gr8 job.
Im gonna do mine either gold or red one of these days.
Hopefully they'll turn out as good as urs did.
cheers man, i had them a flat blue before, but was so dull, it comes in red gold green, heaps of sick colors, all i did was give them a sand down till was smooth, then got mag cleaner to get all the brake dust of, then just prepsol, left them to dry, 4 coats of silver primer, 4 coats of blue, just one thing, make sure you get all the brake fluid out of the caliper cos it can oozz out 1/2 way through and wreck it, and also becarful the brake line is clean when reattatchin it,
should i be taking the calipers off ?? or did you just cover the brade pad thingy at the top ?
so you sprayed it with primer heaps, then the actual paint ?
How many cans did you go through to do the front 2 ?
Now the question is.. what color do i want to do em ? my cars black with white wheels.. Im not good with decisions :D
yeah u take them of completly, i went through 1 can of primer stuff, one can of blue for the frount, and still got enough for a 3rd i recon, with ya car i recon a gold would look ok, whatever ya color scheme is, i recon black and green go ok too, but dono if they will suit the white rim
sorry for being anoying :)
if the take the caliper off, is it easy to put back on.. like there wont be any alignment issues etc etc ?
na mate just 2 bolts and the brake line, then to put back on just seperate the pads, and put bolts and line bak on, that easy, then bleed ya brakes all good
They look great, they're a lot shinier than my blue calipers. When I did mine I used VHT brake paint & finshed with a glossy top coat.... but, I want yours dammit :) . I might have to try this dupli-color metalcast anodized paint when I do my rocker/ cam covers.
They look great, they're a lot shinier than my blue calipers. When I did mine I used VHT brake paint & finshed with a glossy top coat.... but, I want yours dammit :rofl: . I might have to try this dupli-color metalcast anodized paint when I do my rocker/ cam covers.
yeah its a wiked paint, they turn out soooo dope, and i think its cheaper then normal stuff, i had that cull vht crap b4 but this is the stuf ya want
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
