mettams are awesome for doing weldjobs etc, and they are real cheap for stock exuast system.
for my gtr ill be getting a N1, love the sound and they arnt 2 loud.
i bet the one from mettams will be hell loud.
damn right it's loud, loud enough to be slapped a yellow for me :D
1. DONT COMPROMISE
2. DO IT ONCE - DO IT PROPERLY (if it takes alittle longer to save, do it, it will be worth the wait).
Exactly. Why settle for a droney custom exhaust when you can get the TRUST/Apexi Jap bolt-on stuff that's of higher quality, sounds better, less in-cabin drone and can be easily DIY.
Never comprimise on an exhaust, you'll have to listen to it every time you drive so get it right the first time.
Hey every1 thanks for the input, i have narrowed down my choice of exhausts between a HKS High Power and Fujitsubo Power getter. I have heard the Fujitsubo is really good, maybe better than the High Power, but i had never really heard much about them until yesterday so im not so sure. The price difference is neglible between them but the Fujitsubo is stainless steel all the way while the high power is just the muffler and the rest mild steel. Anyone have either or know which is better...ie less bends and stuff
on my car I have got the hks 3" dragger and the noise coming from it is so quiet it is amazing and the extra power it has vs the stock is incredialble I am yet to get the front pipe/dump just need to find out if hks does this as I would prefer the complete system from 1 company rather than bits from here and there
the cannon on mine is very big think it is a 5" job but so quiet
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
