As i no longer drive a 33 coz i have a 34 my username doesnt suit..... any chance i could have Greeny? i did i search and couldnt fine one with that name
thanks in advance
Michael
thanks in advance
Michael
Sorry mate, Greeny is already in use as someone's logon name. It won't show up in the member list because their display name is different, thanks for checking though, it does help!
pls change mine to: theAviator
cheers. chris.
Done!
hey, cant edit the previous post, could you change my username to GoAhead..... and forget about the previous suggestions
thanks in advance
Michael
Done mate, you'll have two notifications in your email because I read your original post before noticing this one lol. Ignore the Michael34 one, your name is GoAhead as reqested ;)
Would it be possible to please get my name changed to suraido
Thanks!
Matt
Yep, done :D
Hi mate, can you please change my Username from SilverbulletR33 to SilverECR33 , can I also change my Email aswell, ?
Yep, you should be able to do that through the "My Controls" button up the top (or click here ). Enter your new email, click the link in the confirmation message, job done. If you have any trouble with that then let one of the admins know and we'll manually verify your new email and update it for you.
Oh and name changed :D
dont u guys do a cleanup? i see alot of accounts made up to 5 years ago with like 3 posts only. names in which I would like to be able to choose from.
Not atm mate, I personally wouldn't mind a bit of a cleanup happening periodically (if you haven't logged on in 3 years chances are you're not going to do so any time soon) but at the moment it's not really necessary, dormant users don't take up much space or slow things down so there's no harm in leaving them. Other than people wanting their user names they don't cause any problems. If you like though, put a suggestion thread in this section about it and if you can convince Christian that it's a good idea, it'll be done :D
Hi, could i please change my name to Beez35.
Can I please get my name changed to Kitty34
PLEASSSSE :)
Both done!
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
