It's all right for tonight, cruising in a corvette and feeling alright!
matty can u sms me ur moby number i dont think i have it nemore, 0417 608 538, i have to wait till tanya finishes work at 9 but should be cool ill catch up i guess.
  • Replies 100
It sure feels like it. My car has not run properly since 3rd or 4th Quarter last year. I will admit it has spent some time in the garage with me just too annoyed to do anything about it.
I have known what needs to be done to fix it since mid April, but the budget has been the next problem. I have ordered some of the stuff I need now so it will hopefully be running by track day, if not definately by next track day and hopefully a few cruises before then.
Good to See, was wondering when was the next Meet.
My car running all sweet after few hick-ups. and now running 10psi
See ya's there.
Don't forget the Long pants and jacket.
Later guys
Only problem is I will be in either the sedan or mini as the GTR is away getting a few more goodies added to it. :rofl:
Got one question, is your dual dragger melting your rear bar?
Only problem is I will be in either the sedan or mini as the GTR is away getting a few more goodies added to it. :D
Hey mate.. bahh take teh beast out this thurs!
btw, my zaust is fine, i left it just enough cap for it not to touch the rear bar.
What cats did u end up using? i had to use 2 oval cats made by toyota..
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
