i always wondered what that was too...
possibly an emissions sorta thing? i know the turbo cars don't have it and require a charcoal box for importing - but mine didnt need one (charcoal box) so i figured this could have been it?
:confused:
https://www.sau.com.au/forums/topic/75818-air-resonator/#findComment-1391095
I think it has 2 purposes:
1. reduce intake noises (like a resonator in an exhaust system)
2. provide a reserve of air for the engine to take in should you suddenly floor it
I read an article from a link in a thread on here somewhere that experimented with removing this and replacing it with a straight pipe. The engine lost torque and intake noise was louder with it removed.
https://www.sau.com.au/forums/topic/75818-air-resonator/#findComment-1391187
Its used to stop reversion through the intake system during throttle transients. Its not used to provide a resverve of air for snap throttle. They also used them on all the older XR6's and maybe the 8's cant quite remember.
https://www.sau.com.au/forums/topic/75818-air-resonator/#findComment-1391977
I have removed the resonator and replaced it with a piece of 3" pipe, on my R33 GTS25, I don't know about the car loosing torque, but without the resonator the induction is quite noisey, when the engine is under load, it kinda screams as it hits 5500rpm.
I'll post up a pic tomorrow of the set up I have got.
https://www.sau.com.au/forums/topic/75818-air-resonator/#findComment-1392329
because turbos presurize the intake air, where as the intake air on an NA is sucked through, but not continuosly, it pulses at high frequency, the chamber acts as a damper and smooths the air being drawn through. there was a big right up and tests done a while ago in HPI, different sized ones give different amounts of power and torque, sacrificing power in other areas, and a decrease all round without one.
https://www.sau.com.au/forums/topic/75818-air-resonator/#findComment-1393619
  • 3 months later...
I Have done this mod, as I said in an earlier post since then I have had a bit of time and experimented around with it, and after a few back to back road tests there is a loss in torque, not a great deal but still noticable.
With out getting both systems dynoed It's hard to tell which has the better top end power, but with the custom intake the car has awesome induction noise :)
https://www.sau.com.au/forums/topic/75818-air-resonator/#findComment-1605934
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
