when my head was taken apart the idiot bashed the 12 inlet guides out with a punch and rooted them beyond belief. all the guides had a bit of wear but were still fine to use, the engine had done 100,000km or so i believe. if you have to replace them with new ones, there's a trick.
new from nissan they are $90 each or something stupid like that. aftermarket ones do not exist (at least, my engine parts stockist could not get them) but we measured em up and found:
OD: 10mm
Length: 38?mm can't remember exactly.
anyway turns out the CA18 uses exactly the same measurements, but the guide is physically longer. buy 12 of them for $100 or so and lathe the ends off to bring the length down. works a treat!
Get a quote from a local engine reconditioner to have the guides k-lined, which is a bronze insert used after the valve guide bore is reamed oversize. Usually cheaper than new guides, plus has better wear characteristics.
But before you do anything, have the valves measured for wear as well as the guides if there's cause for concern.
  • 2 years later...
I won't k-line these heads, they don't last. Use CA18 guides as described above. heat the head to remove them and heat the head and freeze the guides to install them. The only time i've seen guides worn is where they have had k-lines fitted, I've also seen a CA18 head where the guide has come loose. K-lines have their place, just not in these engines.
  • 6 months later...
Nothing at Rocket - waiting for a call back from one of the boys at Hi Octane. I called them to start with but they said that all they kept in stock were the Tomei Beryllium ones and there's no way known I'm spending 700-plus on valve guides.
  • 1 month later...
does anyone know if the r33 valve guides also fit the r34 NEO? And when would i start to consider replacing them for a/m? Besides the obvious being worn out, is it the power or the rpms that factor? I will be reving to 8000rpm ( rb25/30) and 700rwhp. for argument sake they were in good condition, should i still go a/m? tomei seems the way to go.
yes i know...and pretty dam cheap compared to some here in aust. But do i need them? 8000rpm and 700rwhp? My stock are fine and head has come back from engineering.....So if i decide to go a/m its the downtime waiting for delivery and the extra labour involed. Workshop said i didnt need them but just want to get others opinions
i spoke to a supplier and they said that tomei rb25 and rb26 use same guides..Can anyone confirm this? Also if r33 guides would be the same as r34? Im thinking i should replace just to be on the safe side. Would be good to hear from people who still used their standard guides and what power/rpm they achived
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
