hey guys
Turbo on rb25det shit itself so bought a aftermarket bolt on job (nothing too crazy just a tiny bit bigger). It's running stock boost, FMIC, POD and full 3" system.
Take it for a drive and it runs fine, boosts fine and seems to be ok, but after a short drive (<10KM) and no flogging got home looked under bonnet of mates car and the manifold was glowing red hot - took ages to cool off too - looked like it was about to melt!
Rang up some guy who said "it's running very lean don't drive it"
it's still running stock ECU - running lean would cause this? He was going to buy a SAFC - would this fix the problem????
thanks for replies
https://www.sau.com.au/forums/topic/76132-manifold-about-to-melt/
it can become red hot with the standard turbo, but usually only with a flogging of if it has a crap exhaust, if u left the heat sheild off maybe its just that u never saw it glowing before. but yes best to check a/f ratios as leaning out will make it hotter and brighter :rant:
well no dyno around here - nearest would be 300km's - well there is one but it's very dodgey and useless operators...still a 30 min drive!
he was told that he needs a new fuel pump but i reckon thats a load of shit....igf the air/fuel is low the SAFC can fully control this correct?
yes it can u can do that
but keep in mind r33 fuel pumps power limit is around 200rwkw(which your friends car would probably be close to)so if it is around that maybe its time to change it, they are not expensive anyway and a few people have had them fail causing the engine to lean out and die.
i dont think the ecu would let the car run lean or make enough power for the pump to run out of flow. it will hit fuel cut before that happens. i dont think a safc is the solution if it is running lean either. I recon your car is fine my manifold glows red hot all the time you will notice it more at night
well here's a few other things
1. it has a fuel cut defender installed
2. i think he as had the crank angle sensor off - placed it back exactly where it was when it came off though (apparently)
checked all water lines (cracked seal a bit) and they are fine
in regards to it being normal - it's is glowing like a molten bit of steel - litterally looks like it's about to melt!
Upgrading fuel pump, a SAFC would still be necessary wouldn't it to control everyhting?
Errr.. in regards to #2 I think you should double check to see if it is up the right way. As DNB said, retarded ignition can cause the heating of the manifold
What about an inlet manifold leak? This would make it run lean. I seem to remember a mates rotary whos inlet manifold glowed red hot due to this problem. Dunno the ins and outs of it though. Check your plugs; if its lean enough to cause this problem, the plugs will show it.
that many stock manifold/turbo cars i have seen glow its crazy.
remember the stocm manifolds arent of $$$ materials.
XR6 turbos do it, my old coupe did it... my current doesnt anywhere near as much as its thicker metal etc
shaun, if the car had an intake leak, it would run rich as buggery. the afm would detect the air coming in, put in the fuel required for that amount of air, then the air disappears...leaving you with fuel, will run badly.
an a/m turbo will indeed change the a/f ratios, if its putting in too much air and the std components cant handle it, thats why the turbo is usually done last, too many ppl buy a turbo and put it on and drive away....then they are up for a full rebuild, when all they needed was a fuel pump, injectors and an ecu.
a safc will fix it up no probs, if tuning is too difficult, get an apexi pen type turbo timer, it shows a/f ratios....dont live by this reading as it can be fairly rough, but it will tell you whether you are way out. you can then tune the safc to what the turbo timer says...if the readings are between 12-14 under boost, the car should be fine, over 14.7 is running lean.
just a note, the car at times will run lean, such as on idle, and when you back off the accelerator, its supposed to do this, when you get a a/f gauge, it makes you worry when you see it the lean side off the clock.
cheers
Linton
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
