I spotted that one on yahoo the other day. L28 stroked to 3.1, dry sump setup, triple webbers, s13 sus from what I could make of the translation. I have seen those wide body gaurds in use on another white DR and it look horrid but actually looks half decent on that car, at least it would make fitting my 17 x 10's a lot easier.
I have also recently got prices for that kit not including the wide gaurds and for $2500 it could be yours.
For anyone interested the jenesis website has been updated and the last week with nice new pics of DR30's in japan, including one very nice looking purple one :werd:
Just to throw a spanner in the works - no . That car is hardly neat and on closer inspection would not be tidy . The boxy bits may cover silly sized wheels but did you note the front wheel offset ? , that thing would be bump steer city . There's no way you could get ANY reasonable amount of positive caster into it without the tyres eating the arches .
The GRP A DR30's didn't look like that , and with the best of todays road tyres and suspension geometry findings you can do better . Ill take function over phat looks every time , function delivers lard does not .
