Hey all
I was just wondering how you guys go about cleaning the lenses on the headlights and how you get the lenses off. Ive taken all those little clips off and some screws but the fugger doesnt seem to wanna come off. Is there a nack with it or do you just try and lever it apart because the glue is being a pain in the a$$ to get it apart.
Any ideas?
Cheers
https://www.sau.com.au/forums/topic/76786-cleaning-headlights/
I get the feeling those clips only held the light together while the glue set. Some people say you have to heat it up somehow (water/hairdryer) to pull it apart slowly.
Mine are fairly old and were fairly dirty I just just autosol'led the outside and they were fine - should give that a go before you go to the trouble of taking them apart :)
You can take the front lens off but I wouldn't. Mine had a run from some sort of solvent and they were smokey/foggy looking.
I was convinced that the front was as clean as it could get and the inside must be dirty and so I took one apart (after buying a nice pair from a 4 door).
It is a big job to get one apart and is going to be a bigger job getting it back together.
I will be trying the various cutting compound type products now (watching this space for the best performer).
El Bee
u can not take the lense off, there is a way but you gotta reseal it, i bought a jap cleaner thing that makes a shit lot of difference.
If the R33 is anything like the R32 -- and I imagine it is -- its quite easy to get the front glass/lens off, but it involves breaking the sealant so you will have to reseal them.
A hairdryer is a very bad idea: the heat is too directional and you'll end up either not getting the area hot enough, or melting the plastic.
If you really want to pull apart your headlight, you need to..:
1) Preheat your over to 200 degrees celcius.
2) Turn the oven off.
3) Place your headlight on a rack (that hasn't been sitting in the oven).
4) Put the rack+headlight in to the over, making sure the headlight doesn't touch the sides of the oven.
5) Set a timer for 10 minutes. After 10 minutes, yank the headlight out.
6) Using a blunt bread knife, run the knife in the join between the glass and the rear of the headlight. The trick is to try and cut through the sealant, and gently work the two apart.
Lucien.
pretty sure there are a couple of old threads on this.
before trying to take em apart, i'd definately try a few methods of cleaning. i use toothpaste (sounds dumb but does the job :) ) and a heap of elbow grease and they come up well. the other thing i have done is gone to a panelbeater and got them to basically cut and polish the cover, looked brand new.
if these don't work, then try the oven trick.
I use Meguiar's "PLASTIX" clear plastic cleaner & polish... $18 at CrappyBarn!
Yep, this stuff works a treat. I thought the hazyness was on the inside but after using plastX, it seemed to only be on the outside.
Lucien.
on an r33 the front lens is plastic not glass so im not sure if it is a good idea.
The majority of an R32 headlight is plastic too. The point is not to melt the plastic -- it merely gets hot, and hence you turn the oven off and place the headlight on a cold rack -- its too soften the binding agent.
Lucien.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
