Me and my mate have both got skylines, mines 95 his 93, and both of our drivers side windows wont go up and make this horrible noise.
could i get this on warrenty? i know its a long shot but what u recon it could be and will it be exspensive.
thanxxx
Errr... warranty? What warranty would that be exactly?
Im with for the window motor as well but not being able to see or hear what it does makes it hard to diagnose. Could be a number of things. Are there any scratch marks on the window at all?
Yep my skyline does this too. In my case it is missing teth off the power window regulator, which makes a rattling/grinding sound at regular intervals. I just need to go buy another one from a wreaker.
mine gets stuck down and wont go up when i pull on the switch, no noise though. Usally a swift knock to the carpet pad bit in the door with my elbow makes it work again. Thats just a tip incase it gets stuck down in public or something and you dont want to leave your car vunrable to stereo theives.
mine on the 32 is the same so i pulled the switch apart and cleaned up the contacts and it works a bit better but i have to do this every 2 months or so. i think the warranty he may be talking about is the avwn?? one you can purchase it for a bit extra after you buy the car and it covers most of the parts on the car to a certain value. i know it came in handy for me when i need to get the clutch master cylinder redone basically paid for itself there
hey there are others out there i thought i was the only one lol i have a 1993 r33 gts same thing drivers side wont go up or down passangers is fine
a find if i hit the carpet near the door handle it works fine i look like a bit of a d!ck hitting my car all the time lol if enuff ppl complain i cant see why nissan wont do some sort of oops my bad ill fix it job
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
