  • Replies 345
DRAGTS,
these have an opening bid of 55,000yen.
they have a listing of 298,000Yen new.
im guessing these will close at around the 140,000 mark. perhaps less.
ballpark figure landed at this stage is $2750. could be less. very hard to say so early in the auction.
charles,
VOLK RACING TE37 suit GT-R
18x10.5 +15
closing June 21st
less than 100k's total travel on this fine set. these may as well be selling as new items
Did you close off the bids? If not, what is the price?
If sold, have you 18x10.5 or 18x11 TE37 coming in soon - prefer white
Highlander
gday highlander,
those bronze TE37's were passed in. they will relist.
there is a landed price of $4500 on these.
as for white ones, there is one set available as displayed on page 5.
these are a 18x9.5"
if you are seeking 18x10.5 or 18x11, we can order them in for you.
PM me if interested.
cheers
Charles
Just a question but Black LM GT4's are as rare as rocking horse shit huh?
Just that i would love to find/get a set in 18"
Did they only come in flat back or glossy?
Or both?
Lm-GT4 come in a semi gloss black (if that helps)
Cheers.
Charles.
Next question is What is a rough price for a set of 18x8 with a GTR offset (I have a GTS4 so i'm guessing thats what i need?)
the black LM GT4's are a special edition compared to the rest.
a landed price will be approximately $4000.
we can give a firm quote if this price tag fits your budget.
Well i WANT those rims so looks like i'll have to say goodbye to a new turbo for a while! I'll let you know when i'm done saving more :whatsthat
What are the standard colour ones worth? Much less or hardly any difference?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
