Yes, block of wood under the diff.
At the front, jack under the X-member.
If from the side, DO NOT JACK ON THE CHASSIS RAIL (that's the one nearest the middle of the car), it will simply collapse under the weight.
https://www.sau.com.au/forums/topic/7807-r32-jacking-pionts/#findComment-114070
Why would you not jack up on the chassis rail, this is the strong part of the chassis, whenever i put a car on the hoist i put the rear pads under the front of the rear subframe mounts and the front pads under the chassis rail near the front.
The only other place to put them is under the seal pannel, this is a ridge near the edge of the car on is where you put the small jack to change a wheel, not big enough are to lift up on the hoist though.
https://www.sau.com.au/forums/topic/7807-r32-jacking-pionts/#findComment-114308
it is not advisable to jack on the chassis rail unless you are using a hoist as just jacking one chassis rail at a time puts to much pressure on a single point as it can colapse or bend the chassis section up
:eek:
https://www.sau.com.au/forums/topic/7807-r32-jacking-pionts/#findComment-114451
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
