  • Replies 67
Really depends on price and whats involved in the package for me......
I am interested, but I'm not driving 2 hours for an hours worth of expensive karting, when I could go 30mins down the road here and race around in a cheap kart.
So yeah, interested, but depends on package details.
https://www.sau.com.au/forums/topic/78368-go-karts/#findComment-1433001
speaking out of experience...
Eastern Creek Karts your looking at paying around $170-190 per person for a 3 hour "mini grand prix" session.
on the other hand....
you can go to Fastlane @ Minto [where i held the ns.com go kart day] and it ended up being like $45 per person, for the same sort of event.
I think the general thought of paying the EC price is that for that sort of money you could attend a track day / wsid day etc and use your own car.
everyone had fun, everyone thought it was value for money which was also important!
i think they do max 50 pple at a time there though.
here is the thread if you want any info...
http://www.nissansilvia.com/forums/index.p...opic=92712&st=0
as you can see from the general response everyone enjoyed themselves which i mean for $45 is pretty damn good :P
oh here are some pics also for those who have never seen the track before.
http://www.mys15t.com/gallery/view_album.p...umName=go-karts
cheers hope this helps you with your organisation for the day.
-mark
https://www.sau.com.au/forums/topic/78368-go-karts/#findComment-1441933
Whats the quality of the Minto Karts/track like though?
I did an SAU Corporate day about 18mths ago and the day was very good. From memory it was 3 heat runs and a final grand prix all with decent karts and the timing system.
Possible interest here.
https://www.sau.com.au/forums/topic/78368-go-karts/#findComment-1441970
Im interested in $50,
But certianly not $175
What karts do they have at minto?
2-Stroke racing?
The best karts i have ever been on where on the way to Port Macquarie, they were raching 125cc 2-stroke cars the ones i use to race on and they were awsome...
Have the minto ones got a speed limiter?
-SINDOWS
https://www.sau.com.au/forums/topic/78368-go-karts/#findComment-1442721
Id be keen... just about any evening Mon-Sun.
Minto is crap. Its slow and you do not even need you brakes. $50 is good value but id prefer to spend the $150. (Although the trophy i got from the last corporate day there is pretty good -heheh).
I was going to go to a 4 hour (or was i 6 hour?) enduro at easterncreek with another club last year. Im pretty sure it was $150 each for 4 hours of action. However you had to be in teams of 4 and you divided your time between the 4. Full pits stops, qualifying.
You need a minimum of 30 people.
You also had to pay like $15 for your license (which include 5 minutes in the slower karts). Then you can drive the faster karts on the day.
https://www.sau.com.au/forums/topic/78368-go-karts/#findComment-1442766
i am keen on a team enduro session. would be awesome fun, and then you can share the cost amongst a couple of mates (say 3 man or 4 man teams).
Dan tried to organise this last year but everyone said yeah i'll come, then bailed when it was time to pony up the dough.
https://www.sau.com.au/forums/topic/78368-go-karts/#findComment-1445161
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
