266 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I start mine and let it idle for a couple of minutes if possible.. mainly because it drives like a pig on cold start about 50% of the time. But if i'm rushed I start it, wait 30 seconds then drive. Either way I stay under 3000rpm and don't boost it until it's warm.
It's a waste of time to idle the car up to temperature though.. the prolonged operation at low temperature and low oil pressure wouldn't be good for it. Also, if you idle it then the engine eventually warms up but your transmission is still stone cold so caning off after that will hurt your gearbox/diff.
30seconds idling + driving moderately is the best way to warm up a car IMO.
B/C on idle, the mixtures are rich and are washing the oil off your cylinder chambers, causing more engine wear.
7yphon has the right idea, that is the best way to prolong engine life.
I usually wait until the oil pressure goes up before driving, so it is after 10 seconds or so.
Just drive off, and take it easy. You gearbox and diff need to circulate oil too you know
Thanks I never knew that.
I might stop warming her up for 5-10mins heh I thought I was doing the good thing.
YEah well if i have time i give mine a little bit of time... But otherwise yeah baby her until she is warm... But i spoil my girl - she is getting old - too scared that if i fang her when she is cold or treat her bad she'll die on me... But then again - when her heart dies i can get a new engine cant i???? hmmmmmmm *ponders thoughts of turbos in the sleeper...*
yea fore sure
you should always warm your car up. If its your daily driver let it idle for a minute or so and then drive it off taking it slowly untill the temperature gauge gets off C. If you idle it for more than a minute or so say 5-10 minutes your are wasting time and also causing unnecessary polution.
remember the drivetrain needs to get warm too not just the engine!
I don't let me car warm up as i'd be waking the family / neighbours. I just wait a few seconds for it to gain some oil pressure, and drive off boost & below 3000rpm for the first few minutes of my drive.
However, I don't "baby" like driving fifth gear at 60km/hr, more cruise at 2500rpm or so... wouldn't driving at low revs / high gear under load put lots of stress on the engine and if it's cold, do more damage than good?
yeah i would think so... I was blessed with a long down hill st at my old place, so i used to just cruise down the road and that gave her the warm up she needed... I just get frustrated at ppl that start up straight away and then drive like the car is at op temp.... My flat mate does that (poor old car)...
Yeah everytime without fail. Always warm up until the revs drop a bit, giving the oil a chance to circulate. Don't spend a ludacris time though as idling the car for long periods can be bad(unspent fuel slips past the rings and goes into the sump, decreasing the oils viscousity). 2-3 minutes idle is ok. Then i drive like a granny not revving over 2500rpm, this warms up the gearbox, diff and brakes without putting strain while the oil is cold. When stopping the car i ALWAYS go off boost for the last say 5 minutes of the trip to use air to cool the oils and fluids. Then i idle it for 30 seconds or so. Can't stand people who thrash their car then leave it idling for 10 minutes and think they've made up for the damage.
I always start my car, wait for oil pressure, usually a few seconds, then drive.
I try to keep the revs under 4000 until its up to full operating temp.
But it will warm up quicker by driving it straight away, then just letting it sit there idling.
While its cold sitting there you will cause more damage and wear then getting it up to temp as soon as possible.
Either way, todays oils are very good at all temps. So just start and drive.
Anyone that sat there car and didnt drive it until the temp was up would be a true fruitcake.
Just drive straight off and don't boost or rev too much for the first 5 miuntes!!
If you idle for longer thatn 20 seconds you are:
1. Wasting fuel
2. Increasing pollution
3. Wasting some of your life
4. NOT doing your car any favours.
These are modern cars. They are made to be driven straight off.
CASE CLOSED
I normally give the car a couple of mins at idle after starting her. Then I drive below boost till the water temp is around 75degrees.
Yep tommo, I noticed that the knock level increases if under 2000rpm and in 5th gear than if at higher revs and 4th gear. So I guess it's bad to put the car under any load (even low in the rev range) when it's cold.
Under light load the rings/pistons will tend to sit more central and run up and down the bores more evenly then when the motor is under load as then they will be harder against one side of the bore then the other. (This is why new motors need to be put under good load to bed the rings)
So i guess light to moderate load is more important then revs alone.
I asked my engine builder this question as I run forged pistons etc.
He told me to start it, put the seat belt on etc, this is around 30secs of idling max, then drive it but drive it soft with low rev's but not too low as to make it labour.
In other words, change up at around 2500-3000rpm with a light foot.
Do this until the oil pressure is down, in other words oil temp is up.
Ignore the water temp as oil is not up to operating temp for approx 6-7minutes after water temp reaches operating temp.
The idea is you want as little time as possible running a rich mixture as running rich washes the oil from the bores in turn glazing them up causing the car to have poor ring seal, it also gives the forged pistons less time to slap as it only takes 7minutes of light driving to get everything up to temp.
Simply idling alone will not bring piston temps up enough within 5-10minutes so they don't slap.
It also wastes fuel by letting the car idle. From memory its around half a litre for every 30minutes or was it 1hr idling, one of them. :)
So in short. I idle the car for around 20-30secs then drive lightly.
Waiting for the car to warm up is a waste of time, fuel and engine life.
That will be the ign map, nothing to do with engine vibrations as they are a different frequency.
After getting into the car I spend about 2-3 minutes fiddling with everything so I guess that is more than enough warm up time.
Besides, its pretty much stock so I'll wait till there is some serious gear in there before I take this warming up business for real.
I like one of the previous posts about the Turbo Timer
Go set it for 10 mins and lock the car.
Jump in and set to go!
Got me looking now for one.
Be worth the $120 to be able to have a nicely warmed motor.
Particularly after a night shift when I'm straight out the door and into city traffic and duckin' weavin'
No time for warm ups there!
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
