266 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I like one of the previous posts about the Turbo Timer
Go set it for 10 mins and lock the car.
Jump in and set to go!
Got me looking now for one.
Be worth the $120 to be able to have a nicely warmed motor.
Particularly after a night shift when I'm straight out the door and into city traffic and duckin' weavin'
No time for warm ups there!
u could do that or u could just get a remote engine starter like me and turn the car on from inside the house and let it idle for a bit
you only really need enough time for everything to be covered in oil. 30sec to a min should be plenty of time. Idling might help with lubing up the engine but the cat doesn't like it and will kill it faster.
Correct me if i am wrong but after everything is covered in oil the only problem is parts heating up (expanding) at differnt rates. So if you wait untill the water is up to temp then the whole block should be nice and warm due to the hot radiator fluid running through everywhere. So once your water temp is up you should be right to have some fun.
Aslong as you don't thrash it for the first few minutes it will be fine.
I usually back out of the garage, and close it (around 30secs) and then take off slowly until i get out of my suburb (3-4mins)
When i start my car however, the oil light stays on for about 2seconds then goes off.. is this normal??
The oil atm is sitting halfway inbetween L and H (on the dipstick)
Just drive straight off and don't boost or rev too much for the first 5 miuntes!!
If you idle for longer thatn 20 seconds you are:
1. Wasting fuel
2. Increasing pollution
3. Wasting some of your life
4. NOT doing your car any favours.
These are modern cars.  They are made to be driven straight off.
CASE CLOSED
My car won't move if I don't idle it for atleast 1-2mins. It just dies if you put the accel in.
My car is also not stock, so it wasn't "made" to be driven straight off it was made to make more power, handle better and stop better.
Does that mean I'm injuring it and I should try to make it be able to take off in around 20secs?
most oil lights weill stay on for a few seconds. AS long as it turns off and stays off then you should be fine. Aslong as you check you fluids regularly (AS WE ALL MUST) there will be no problem.
Thanks for clearing that up, i was starting to worry!!:P I check it 1-2times a month.
Are you running an a/m ecu? Your car shouldn't really die if you put your foot down when it is cold.
If you have done any engine mods then warming it up at least a little bit would be a good idea. But the best way to warm up your car is to baby it on the streets.
idle for a minute or so, then take it easy till i see some decent temp, usually about 10 minutes or so. which sucks cause it only takes about 10.5 minutes to get to work!
Sounds like you need to find a longer way to work.
Have you guys had a lok in the car manual (if you got it) I have had a look through a few differnt cars manauals and they all say the best way to get the car up to temp is to drive it normally. They also say that excessive idling with kill your cat(if you have one).
Me too!!
I take a detour when going to work now though. It's still only takes about 15mins, use to take 10.
Yeah, I have a "startup routine" in the morning.
Get in the car and start it up. Then put the belt on, turn off the TCS, and adjust the stereo. Maybe clean out the centre console of the various bits of paper that gather in there.
When I see the revs drop from its "cold idle" 1500RPM and the oil pressure drops from 6kPa, I'll drive it at low RPM and load for a while. Luckily there's downhills away from my street, so I'll just select whatever gear keeps it at the speed limit without using the pedals for as long as I can.
Tend to warm it up atleast until the oil temp stabilises.. once it's there - i'm happy.. it's happy..
not good for any cars to just start up and thrash off, can cause a bit of damage - I think.. might be wrong though..
bit like stretching before going for a run eh! if you don't do it, you'll regret it.. if you do - everything is sweet..
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
