I've had my car tuned by 2 other shops and i can say without a doubt that the CRD tune was by far the best... Safer tune and more power the car makes over 10psi at 3,000rpm its super responsive..
The car has built engine GT-SS turbo's but stock cams...
We didn't get enough time to play with the cam gears we are going to do that when i get a set of larger cams and some other things (oil cooler etc) so hopefully she will make some more power!!
  • Replies 95
mate, i highly suggest having the cam gears adjusted. mine went from 220 to 250 kw atw just from that (with the 2psi boost increaed by too). especially since you have them sitting there.
very nice mate. fat looking curve, with plent down low. cam gears could even put you over the 300kw mark.
Well it was a time consideration and seeing as i am planing to get new cams which will mean having to reset them it wasn't really worth the tuning time... Mind you they are set at 5,3 atm from a previous tune..
Although i am sure we could get more from it but 285kw is enough for now....
ahh if they are already set then yeah, just leave it. not much point re-inventing the wheel (so to speak!) if you are only going to replace the cams anyway.
out of interest do you have a graph of the first run it did, with the last one to compare to?
No i don't but the car was making 260 4wkw from the previous tune with a much leaner AF ratio...
Damn that looks nice
I had mine tuned there the other day, basically standard mods - exhaust, boost, power fc
Netted me a nice 227.6 awkw at 15psi on stock turbs.
Wish my dyno graphs looked like yours :P
Heres my graph
Sorry for the thread hijack :(
This really shows how good the GT-SS turbo's are!!! at 90km/h on stock turbo's you car is making 3200nm torque... At 90km/h on my car with the GT-SS its making 3800nm torque...
So not only do you get more top end you get alot more low end response to!!!
Sorry for not returning your calls on Saturday mate, I had my phone on silent from when I went to the gym the night before and only realised when I was out painting the town red Saturday night! :P
Interesting that the car lost 30awkw just from the change back to stock cams... Also interesting that the torque falls over after peaking so early. What boost was this run at? 1.6 bar/24psi right? From all accounts, that's the limit of the GT-SS efficiency curve, so perhaps the camshafts DO make a big difference?
It will be interesting to see how the bottom end is affected by the bigger cams. I distinctly remember the car pulling a little harder down low with the stock cams (which is what I was after)... I'll see if I can dig up the old dyno graph of the car with the 260/260 poncams.
I'll also dig through the garage to find those cams... I have no idea where I put them after we renovated the garage :-/
Sorry for not returning your calls on Saturday mate, I had my phone on silent from when I went to the gym the night before and only realised when I was out painting the town red Saturday night! :)
Thats ok mate!! ended up spending like 10 hours at CRD :P That was running about 22psi but a very safe tune and no playing with the cam gears..
From what Jim has told my and what i have heard around the traps the cams make a big difference...
Oh btw did you know the powerfc pro has a 2step luanch feature :( can't wait to try that out on the bottle :D
Oh btw we got it to idle at 1000rpm and we found out why it uses soo much fuel... Dead 02 sensors!!
:P
If I had a dollar for every GTR that had dead O2 sensors........... :(
Yes, I knew that the Pro had launch control, but what it does, is cut ignition spark which causes it to dump a ton of unburnt fuel into the exhaust where it promptly ignites and tries to blow MASSIVE flames.
Don't use it unless you bolt in a straight through pipe or hollow cat-convertor, because it's the fastest way you can reduce an expensive cat-convertor into a molten lump of restrictive metal :D
Try not to hit the rev-limiter too much too, because it's an ignition cut as well, which causes the same dumping of unburnt fuel. I purposely got the PowerFC Pro because the ignition cut is much much nicer on the engine than a fuel cut which normal PowerFCs use for a rev-limiter.
Hi "kabab"You now also have 1st hand experience of just how good Jim @ CRD is with his dyno tuning - proof with your back to back comparison tuning with other GTR tuners 'so to speak...'
He is the guru!!! I back this statement up with my personal experience :P
Congrats on your results mate :(
Marko.
Could do with gearing if i am not mistaken you have a trick gear box in yours, was it dyno'd in a gear that was 1:1 ?
aha! nothing get's by the kabab. you are right, but it was done in 4th which is still a 1:1 ratio. just 1, 2, and 3 are slightly different, 4 and 5 are as per standard 32GTR.
I got them to reference the graph against rpm anyway as I find it easier for me to understand rather than trying to convert road speed. :P
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
