  • Replies 41
i own one, also own a 32 gtr, and i love it but i really cant answer your question without writing an essay, and i cant be bothered, they get crap fuel economy tho
They can handle big massive turbo's with minimal turbo lag!
They rev high when ported and modified.
They sound so great.
They have shit fuel econemy
They are very light
They sit back in the firewall, good weight distrubution
They are cheap to fix
There is jack shit to modifiy on them
Thats about all...
Ill be buying one soon :Pimp2:
my interpretation is thus: It is very similar to the 4 stroke, 2 stroke debate, as rotary's operate as essentially a 2 stroke. Thus while they can burn a lot more fuel per second, and hence get more power, they do so inefficiently. This has become a problem with changes in emissions regulations. However practically you can get a lot of power out of very small displacements, and hence get fantastic power to weights. Similarly because of the large amount of fuel they can burn, they couple with turbo induction very very well. A typical downside is things like that the whole central rotor has to move, and so there is a lot of friction wear on the seals, which has given it a bad reputation (I think) for reliability. Overall many companies and individuals worked on the rotary concept (mercedes, nissan to name a few) however only mazda continued for such a long time (rather like wankel). They certainly have some great positives, but also a number of downsides, which is perhaps why they have never been largely taken up. That's just my rough overall summary of rotaries :P.
I'm in the exact same position as you Lang!
Although I'm off-loading my RX7 for an sr20 180sx X-Type, hopefully, this week.
For me, the 7 was a fun, quick, sidways car. Love the way it looks from the front, hate the back (series 5)
Lang is spot on, they drink! Also I have found that they are very high maintenance, so cbs with it anymore. BUT, they have very high modification potential, hence their popularity and I suppose there's something about a rotary engine that draws people towards it, that I just can't put my finger on.
2mm Ceramic seals can fix that problem :D
New,good seals should last upto 100,000klms with a high powerd engine running sufficient boost levels.
people are scared but they don't understand or have sufficient knowledge, explaining how a piston engine makes power is easier to ur average joe then explaining how there a chamber with a triangular shape thing in the middle which sits on an eccentric shaft and rotates thru a epchyotroidal (spelling) revolution and makes power 3 times per revolution.......
the main reason why rotoarys got a bad reputation of reliability is because thed mazda service folks would replace the whole engine instead of replacing the broken part. My house mate has a mazda RX3 which still running and has never needed a rebuild.
The other reason that the have an unreliable name is that they can very easily run hundreds of KW's and like any engine need to be very well built to witstand the force. A dodgy 6 will still die as 500kw if it is dodgy.
In their stock condition they can be fairly efficant and the RX8 is one of the cleanest cars for emissions. The old ones aren't because they are before the times off emmision control and therfore no cat etc.
The engine is very small and very simple (only 3 moving parts). Because if goes around and around instead of up and down they can rev much higher then a piston engine up around 12000rpm if you really want to.
They are great for turbo's as the engine moves alot of air. This allows for monster turbos on a 1.3L engine.
Overall they are a great engine to work with as long as you have apassion for them and you know what you are doing with them.
Igonr: Each rotor will have 3 power "strokes" per revolution. The 10a, 12a and 13b have 2 rotors so that is 6 power "strokes" per revolution of the engine. A piston has one power stroke every 2 revolutions. Therefore a 12 cylinder piston engine will have the same number of power strokes as a 2 rotor engine. If you move to the 20b (3 rotors) or 26b (4 rotors) then your going to have more power then you know what to do with.
Interesting... thanx for that.
A few people i know seemed to have changed with the wind and are now on the rotary band wagon and i dont know why.
Whats the pros and cons with a rotary engine over your normal 6.
I own a bridgeport RX4 coupe and an R31 GTSX . The skyline is a great cruiser for everyday travel.Its even got a child seat in the back.Economical and goes pretty hard(r32 silver top engine).The RX4 is brutal!!!! Heaps of grunt from the Weber fed 13b(turbos go so much harder too!) But the best thing is the sound.Love it or hate it every one knows you are coming and boy do they look.(Coppers too!).
Fuel economy is shithouse(advise getting 2nd job) especially when you realise that we are talking about 12A(1200cc) and 13B(1300cc) motors.To make good power ie;200 rwk from a rotary costs a lot less than a 6cyl.Check out how fast they go at the drags.Sub 7 sec passes in O.Z!!!!! Some bent 8 cars spent 30 - 40 thou to run 10sec 1/4 times.10sec eng packages for rotarys from about 6 - 10 grand.And still streetable with programmable engine management.Thats why there are so many cars on the track!
The price of a good car is still affordable, remembering most are 30 + years old(unless you have lots of dough to buy late model RX7's).Parts are available for most but more and more expensive all the time.(check ebay.)RX3 is the most popular and buying one is an investment you won't loose from.The price of import skylines has fallen pretty hard lately,old rotary cars have increased.
A lot of people(Simple minded neanderthal types)write off rotary cars because they have never driven one or have had their ego dented by one in a traffic light drag.Typical Holden or Ford V8 fans call them by heaps of names "chook cookers" "beer kegs" and just "jap crap".I could go on forever but you have probably already stopped reading by now anyhow.
By the way, my R31 GTSX is up for sale!!! Not the RX4though.Love the Skyline but need the dough for a new bussiness.If interested call me on 0405 202 395.Wazza.
every time the engine performs one revolution, it combusts 3 times. that's good for power.
And what does a 6 cylinder in-line do??????
The main advantage of the rotary is that the "piston" (rotor) mass keeps moving in the same direction, unlike a "conventional" 4-stroke, in which the piston has to stop twice in each cycle (once at TDC, and once at BDC). So rotaries just keep revving. which is why they can make big power numbers (power = torque * rpm). They have pretty shite torque, but loads of rpm. (diesels on the other hand have enormous torque and shite rpm, but that's )
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
