After a discussion with discopotato03 about getting a bit more out of a GCG Hiflow turbo, i rang Bret at GCG Turbochargers and he concurred that he could adapt a VG30 rear end onto his GCG Hiflowed R33 GTS-t turbo. I then sourced a VG30 from an importer and gave it and my Hiflow back to Bret to do the Hybrid. Bret suggested that it should give a little more with the larger rear end and hold boost to 7000.
After refitting the Hybrid GCG Hiflow, I had a very pleasant supprise after it was retuned yesterday by C&V Performance. I had a tune done by C&V four weeks ago which produced 240kw@tw just prior to competing in round 4 of the NSW Supersprint Ch'ps at Easter Creek where I had a fastest time of !:49:55. Yesterday the GCG Hybrid made a safe 271.2kw@tw.
Should be able to use the extra kw at Oran Park in round 5 this Sunday.
Ian
https://www.sau.com.au/forums/topic/78983-gcg-hiflow-hybrid-on-r33-gts-t/
  • Replies 316
Posted Images
Ian
Well done Ian, that's a great result, it's the extra ~50 rwkw at ~4,500 rpm that impresses me. :)
Hi Gary, thanks mate. Con was very impressed with the larger VG30 rear end and recon's he can get more (he wanted to weld up the gate and get a manifold with external)but with stock innards we called a halt, cause i know that you recon around 280kw is satisfactory.
Ian
Very good. Have you got a pic of the turbo before you put it on. I'm interested to see the physical size of the exhaust housing.
This fits with my theory that an R34 turbo highflowed should make more than an R33 one done the same way. Compressor sides are the same all round but bigger exhaust housing picks up serious gains.
very impressive results mate. What other mods do you have? are you using the stock cams?
Hi Munna, have GCG Hiflow Hybrid Turbo, Power FC, Nismo 550 Injectors, GTR34 Front Mount Int, GTR34 Fuel Pump, Sard FPR, Z32 AFM, HKS Step 1 Cams, HKS adjustable exhaust Cam Gear, CES Split Dump, 3" exhaust. Oil Cooler. Suspension and Brakes have been modified extensively including GTRGeoff's Hycas lock bar. Racing on RE55s Bridgestone tyres.
Ian
Hi Bob. yes i took a heap of pictures of the turbo before i put it on. I have them on the memory card on my camera but i will download them onto the computer tonight and post for you Bob. The VG30 is much larger than the turbine housing on the GTS-t. I know nothing about turbos but the guys that do are like gynocologists and stick 3 fingers into the housing and say, "yes this is off a single turbo 3 litre 300ZX Nissan"
Ian
Will be good to see.
That boost drop would explain the flat top end.  Any idea why it's dropping off like that?
Hi Bob, I have no idea why it drops off, from the impression i got off Con he doesn't like internally gated turbos particularily. Maybe that was why he said he would like to weld the gate and get a externally gated manifold? But at the end of the day I was really stoked with the extra 30kw from the turbo and getting close to the limits of a stock internal RB25. I was so close to buying a HKS 2835 kit for $4000 and i doubt if it would have made any more than the VG30 addition on the GCG Hiflow for the few hundred it cost.
Ian
Congrats Bullant on a good result for the cash outlay . Can you tell us if the spool revs moved up with the larger ARR housing .
I'll stand with Corky Bell when he says turbine inlet pressure is an evil and should be delt with accordingly .
My rantings only , cheers A .
Hi A, thanks for that bit of info you gave me originally. When i mentioned it to Brett, he knew exactly what i was talking about and had done them sucessfully before. He told me to get a turbine housing off a 300 ZX Nissan single turbo. LuckiyI eventually got one from SSS at Girraween for $150. My Hiflow was off the car as i had just broken a manifold stud so I gave Brett my Hiflow and the VG30 turbine housing and a few days later the Hybrid was ready. I'm not sure of what the cost was as I bought a few other things at the same time, silicon tubing and clamps and stuff but I don't think it was over $200 for machining and rebuild. If anyone is interested ring Brett at GCG (sponsors of Skyline Australia).
Driving home yesterday in torrential rain, spoolup appears to be very similar to the normal GCG Hiflow,which is what i want for circuit racing, no lag and response is immediate I'll know exactly whenI race it on Sunday at Oran Park and im going to love the extra 30kw.
Ian
hi bullant 47
can you let me know how much all up the hi flow cost you?  and also are you using the standard manifold??  would be keen to get a similar setup as my current setup has cams and adj cam gears etc the same as yours
thanks....brett
Hi bretto, I got the VG30 from SSS Automotive for $150 ( some places wanted $500 for the VG30 and JustJap didn't have any) and your only going to use the turbine housing so one with shonky bearing or whatever is OK. I'm not 100% positive but I think GCG charge between $150-$200 to machine and rebuild your existing Hiflow, but please check with Brett at GCG Turbo's. They are sponsors of Skylines Australia. Make sure you get the VG30 of a 300 ZX single turbo. It took SSS two attempts to give me the correct housing.
Ian
There are a few different VG30DET's.
The conventional sleve bearing and the roller bearing.
Is it possible the turbine housings are exactly the same 5 bolt pattern?
Pics would be great, I went to check out a VG30 turbo down at D1, the exhaust housings looked only ever so slightly bigger than the rb20 item they had sitting next to it.
I had a VG30 I bought from JMS some time ago, I went through 2 of them before giving up and getting my money back, the first one squeeled constantly, even on idle. The second had a squeel for a fraction of a second at around 9psi when coming on to boost.
oh yer.. lol That VG30 looked actually quite a bit larger than the rb20 item.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
