Hi SK,
Just back from Angola and have measured the springs as you suggested.
Front
top 118 od
bot 113 od
spring 14
coils 7 total
2 progressive coils
rear
top 113 od
bot 100 od
spring 13.5
coils 8 total
2 progressive coils.
Ps also found the front sway bar is broken not sure how long that has been like that and i guess would not be helping with the loose rear during mid corner.
King Regards
Edited by tacker
  • Replies 378
Hi SK,
Front
top 118 od
bot 113 od
spring 14
coils 7 total
2 progressive coils
rear
top 113 od
bot 100 od
spring 13.5
coils 8 total
King Regards
Front is ~400 lbs per inch (7.1 kg /mm)
Rear is ~370 lbs per inch (6.6 kg/mm)
Yep, a broken front bar is not good for rear end stability.
:) cheers :laugh:
Cheers SK,
If your ever in this part of the world you have a night of free beers.
I am thinking that i still might need some softer springs in the rear, what would your recommend?
Regards
Hi SK,
I have some measurements here, hope you can help me out to figure the spring rates.
I.D: 90/79
O.D: 12
# : 6.650
Thanks SK :(
Sorry for the delay
270 lbs per inch (4.8 kg/mm)
:P Cheers :(
Hey sydneykid im getting new coilovers for my cefiro soon but would like to know what rates i have at the moment, these are the coilovers that it arrived in oz with, measurements are
front
coil OD - 85mm top and bottom
wire OD - 12mm
No of coils - 7.9
rear
wire OD - 11mm
No of coils - 7.25
measurements taken on the car without verniers so may be a bit rough, thanks heaps
Sory for the delay, I missed this one.
Front is ~ 500 lbs per inch (8.9 kg/mm)
Rear is ~ 415 lbs per inch (7.4 kg/mm)
:P cheers :(
Edited by Sydneykid
Couple to calculate please -
1. Coil ID = 98/66 mm
Wire OD = 11.75 mm
# of Coils = 7.25 turns
2. Coil ID = 96/71 mm
Wire OD = 12 mm
# of Coils = 7.75 turns
Thanks
1. 235 lbs per inch (4.3 kg/mm)
2. 225 lbs per inch (4.0 kg/mm)
:) cheers :
Hi Gary,
Got some measurements...
front:
WD: 13.8mm (???)
turns: 4.75
rear:
WD: 11mm
turns 7.25
cheers
Ben
Front = 160 lbs per inch (2.8 kg/mm)
Rear = 200 lbs per inch (3.6 kg/mm)
:) cheers :D
Hi gary,
I've got one for you.
Rears:
coil OD 91mm
wire OD 13mm
coils 9.4
length (lightly captive) 247mm
Fronts:
coil OD 90mm
wire OD 13mm
coils 7.75
length (lightly captive) 190mm
thanks very much Gary.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
