Ohh finally I have experienced 33 stock turbo shitness.
On a cruise today, grabbed for 3rd gear and bannnnnnnnnng.
turbo sounds like a jet, really bad. I think the bearings ****ed up big time, at least it didnt spit out the exhaust wheel!
Ohh well - anyone got any suggestions or have a upgrade for sale! Im looking for low mount, stock manifold internal gated replacement.
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/
I have it set on 10, but usually, its gets a initial spike to 13 psi and drops, It somehow responds very quickly.
Its either now GT2530 or 2540 turbo.
Anyone got one for sale or know of one for or coming up for sale, please let me know.
Regards
Kim
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1444696
Regards
Kim
Id go the gcg highflow with a vg30 exhaust housing for sure. If I were going something from HKS a GTRS or a 2535
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1448031
Money talks. If you have the extra cash to buy HKS, you will end up with a better quality built turbo, a turbo that has been engineered to acheive the power@ higher boost, and better reliability. Also the turbines in a hi-flow turbo can be too big for the housings, which can cause other issues, such as fluttering while making boost.
That's an interesting comment Al, why do you say that over a high flow?
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1450144
your talking about brand new parts which is machined by gcg and balanced
how could they sell you something that isnt balanced or not fitted properly?
if it was a second hand bits or catridge or somethinf yeah ok could be issues
but not with a new bearing kits etc in it, dont see how?
i dont see how hks can make a better turbo when garrett make them in the first place
do you mean the combos avaiable and r and d they put in? you can always get whatever hks in garrett format, just gotta look around and ask the right people
anyway i dont really know what im talking about my clutch is angry and im still on stock turbo so who knows :confused:
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1450275
anyway i dont really know what im talking about..........
no arguments there...........:wassup:
The argument of "HKS Vs Garret" was been discussed numerous times, so everyone is entitled to their opinion.
The term "Hybrid", by definition means; "thing composed of incongruous (mismatched) elements." Now how can you argue that the hybrid turbo can compare to a HKS turbo. The amount of $$$$$$$$'s, research and engineering will greatly out way any Hybrid.
As stated b4, I myself have bought a second hand GCG hybrid and am very happy with the power, but know that a HKS turbo is far more superior. The HKS may not make a mountain load more power, but is an overall better product.
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1450461
guys
I would go for a Nice HKS or Trust or Apexi turbo ,but the MAIN thing that worries me is E P A!!
If I was back in Perth now, itd be getting HKS T04Z treatment, 50mm external gate, Motec, big fuel system, injectors and possibly even forged internals.
If I do this here, I will be raped by police again, I learnt my lesson on modified cars here, and Im defeinetly not gonna be pulling off shit evry time I get a EPA, we modify our cars to enjoy them, not to be looking over ur shoulder every time for a cop or worrying about someone dobbing you into the EPA.
I want simple stock looking high flow, bit more power and a newer reliable turbo.
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1451088
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
