SAU Vic Social Meeting\Dinner - Tuesday 19th July 2005 **DECA TROPHEYS/VIDEOS HERE**
  • Replies 66
Newbies welcome to this right? bloody far enough away ehh and same time as silvia meet (coincidence? heh) but i'm hoping to come :).
Big choice. Silvia meet or a club that actually does stuff on a race track.
I don't think our commitee could, or even should give a rats what they are doing.
In case you haven't noticed it's been the 3rd Tues each month for some time but come along anyway, the presentation should be fun to watch.
Ohh I know which is higher on my priorities don't worry bout that, it's just that one is 10 mins drive, and the other is 30 :O.
Hang on - this is a car club isn't it? And the cool thing about cars I find is that you can drive them.
But despite this I'm constantly amazed by the number of people that complain about having to drive to DRIVE to a CAR meet!
:confused:
:confused:
Thats a fair call... And a damn good point...
REMINDER - Meeting is on tonight and includes DECA Footage & Presentations.
Come along, have a meal and meet some other members.
Plus - a few of us will be at the Casino from about 4.30ish onwards if anyone else want to come before the meeting.
Good to see the clubs money is being spent well Bec
Meeting was great, thanx to all that organised it again... The video footage was aewsome missed out on both events so to see the footage was good for a catch up.. Thanx Joel for the slideshow was good...
Catch who ever is going to Winton up there...
unfortunatly i couldnt get out of work in time to come. I was wondering if its going to be possible to buy/get the footage on dvd at any stage?? or maybe download it??
Top job on the photo and video footage guys! Good to catch up and have a few beverages too!
Can I please have a copy of the "Bass-Video-Whore-Who-Isnt-In-This-Version-Junky" DVD? Thanks :P
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
