Hey guys i dont currently own a skyline but was looking into getting one......the two im looking at are the r33 and r32's gtst.....now my mate has a mkii falcon xr6turbo.......simple........i want to beat him.......the r33's look better (with the 400r bodykit which id put on) but the r32 is lighter if im not mistaken......ontop of the actualy price of the car i was not looking at spending more then 10-12k on mods to beat him......hopefully get into very low 13's or higher 12's on da 1/4....if this is not possible i guess i'll have to go EvoII
Thanks guys
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/
  • Replies 46
have to start of by saying metallica is the best band in the world
secondly, if ur mate a an XR6T you really wont have to spend a lot of money on either a r32 or r33 gtst to beat it. get an exhaust, cooler, fuel pump, injectors (or fuel regulator), chip the ECU and upgrade the turbo and you will hammer him. after all this you will have heaps of money left
and the debate of r32 vs r33 has been going on for ages. it all comes down the personal prefernce
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1450912
The R33's run low 13's when an exhaust, fmic, powerfc and a bit of boost.
Some have even managed a high 12 sec pass with a well sorted rear end.
Grab your self a decent R33 with an exhaust and possibly fmic, drop in a powerfc and it will be running the times you want.
Providing you can drive that is. lol :D
Those XR6T's can launch pretty hard off the mark.
If you can't drive you'd better go the 4wd.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1450929
Well i was thinking of if i were to get one....(r32 or r33) put in exhaust, fmic, sard injectors, fuel regulator, to4 turbo (dont know which spec yet but one with good mid-high torque/power with steel ball bearings), and either chip or full stand alone...plus cams and valve springs seeing as the head makes all the power.......also how much approx is it to rebuild an rb motor with lets say forged rods, pistons and balanced crank etc
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1450938
screw gettin a Rex, ull get hammered shitless on the freeway by an xr6 turbo, plus not have as much cash left over for mods to try to keep up... dont want that. But as it was said, if your a bad driver the 4wd will help from the traffic lights and will give u a large advantage over him.
Get whichever you prefer looks wise as both the 32 and 33 will deliver fine especially if you plan on putting 10k + into power mods into the beast!! You'll be running low 13s easy as in both cars.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1451152
Thanks guys
do you see the word freeway in there?
no
do you see the word 1/4 in there?
yes
will the rex beat a xr6t on "da 1/4"
yes
what car R33 v R32?
I prefer R32.
the money on mods that you say you want to spend you could build a wicked engine (doesn't have to be an rb20... go read the rb30 thread up the top of this forum)
that will destroy many a car on "da 1/4"
xr6t = 1700+kg
r33 = 1350 kg
r32 = 1260 kg
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1451457
Providing you can drive that is. lol :cheers:
What cubes said.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1451542
Then just get a big, heavy stick.
Seriously, decide what you want, then do it. With $20k to spend on a car and mods, youll be able to kill him.
My opinion, to really piss him off, get an R31 GTSX import (still eligable under the now 16 year rule) with an engine upgrade (either rb25 or rb26).
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1452042
Look at tradingpost!!!!!
Why are you bothering getting a GTSt if you already have the plan to mod it. Start with a GTR.
R32 GTR's going for around 23K with a few goodies, saw a black one with N1 turbos and a claimed 250KW @ wheels (something like that).
Get something that already goes fast so you know what you are getting into the day you buy it.
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1452133
I am with psybic just spend a little more on buying the car and less on the mods a R32 GTR goes for around 22k - 23k with a few goodies and then if you have to just add powerfc, wolf 3d so you are able to fine tune then a fmic if doesn't have one. Little bit of boost you will eat him alive that way you get a better car in my mind and you might only have to spend 3 - 4k instead of your 10k
https://www.sau.com.au/forums/topic/79647-r32-vs-r33/#findComment-1452192
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
