i have a link in my car was in there when i got it few shops have told me to piss it off if i want 200rwkw
last tune it got a shit 140rwkw on stock boost
my next goal is like 185rwkw on 11psi with new Dumps and hi flow cat mods r
Link computer
PWR front Mount
K & N pod
cat back Exhaust 3" with 1 box
Had Aftermarket BOV took it off due to defect feels a little more laggy
If links r ok where the best Shop to get it tuned
https://www.sau.com.au/forums/topic/79922-how-shit-r-link-computers/
There's nothing wrong with Link ECUs. The tuner is the primary factor in how the car will run with an aftermarket ECU, not the ECU itself (unless it is a really limited one). They're used everywhere in NZ, so I'm sure the computer is fine. I'd head to Sydney.
I had a Link in a blown celica 10 years ago and it was shit. Their customer support was so pathetic that an australian distributer i bought it through ceased his dealings with them and refused to sell them.
I'm sure alot has improved in 10 years, but it's a case of "once bitten - twice shy" for me....
im running a link with my rb25, i think they are a great computer if you have a good tuner. my was tuned by tim sheather of electronic automotive at epping victoria. i personally would go with someone who is a good tuner and go with the ecu they recommend purely from a convenience stand point, ; ie no good getting a link if there is no one out your way that can tune them.
links are great running one in the r33 gtst and it finr had it tuned by AVO in melbourne the main Ausie supplyer and they are great i got 205Kw a the wheels on stock turbo and have been running for three years its great
I have personally had both a power fc and now a link and i would have to say from my experience i much prefer the link although that is for my setup so different things suit different cars. Your main problem would be the people you got the advice from don't know how to use them. I'd head down to Sydney as there are are few shops here that are good with them.
Care to elaborate, or at least point to some supporting evidence?
Cheers,
Lucien.
well... If people read the difference between I wouldn't have to. Also, just because a tuner is shit, or doesn't know how to tune a link, doesn't mean they are shit, and you run all over the internet trying to tell everyone that.
ok.
Thinks the link has over Powerfc -
Link Has Knock control
Link has Launch Control
Link uses the STANDARD boost solinoid on the R33's as a fully fledged electronic boost controller
Link comes with all the gear to plug straight into a laptop
Link ECU can have a MAFless tune
Link ECU has MANY more tunable options.
My advice, keep the link, get a tuner that knows what he's doing. There is a Tuner here in Mackay that specialises in Links, seen his work, he's tuned lots of 300rwkw+ cars, and guess what? He even tuned my PowerFC with the hand controller, and got 210rwkwn 420 nm torque, with it being a stock turbo, stock motor, FMIC and full exhaust.
I good tuner will never say something is shit, just because they don't know how to use it properly.
No point getting defensive, I was honestly after your opinion. Pointing to the paper specs is not very helpful as they tell you nothing about what its actually like to use.
What about cold start, aircon, etc etc? Are all of these accounted for out of the box or do they have to be tuned? Some of those features are available in various forms of PFC (Pro / D-Jetro) or through addons, and its debatable how useful others are.
Lucien.
I had a link running my rb20 (t3/4, cooler, 3", etc) and it ran very well, although fuel economy was pretty poor, prob due more to my right foot tho....
I loved how it ran on a map sensor, NEVER back fired, stalled, or anything, and that was running either standard BOV, aftermarket BOV, or no BOV (tried 'em all).
Then, when i did an rb25 conv. i used the link on that too, which seemed ok, cold start was always a bit of a prob tho, it would constantly rev at 1000-1100rpm even when warm. Same deal as above with the map sensor.
Not sure about air-con, as the condenser was ripped out because of cooler piping.
I had alot of workshops tell me that they were shit, ended up at AVO who did as good a job as they could. I never tuned it for max power (sold now), just tuned to be driven (stock psi) after the conversion.
As stated already, they're VERY common over in NZ, and if tuned correctly, will stand up against most mid range ECU's.
But, having said all that, i've 'heard' that u cant really beat the power fc 4 an rb25.... choice is yours.
The link plus also has anti lag, thermo fan control, intercooler water spray control, 3 stage shift light, boost cut, maps that allow tuning to 10,000rpm not 7000rpm like most ECU's. There is more in the ECU but i cant remember them all
GRACER makes 510kw at all 4 with a link and it drives perfectly so they cant be that bad ;):) We (Advan) use heaps of them.... we have about 15 of them getting about Sydney now installed in everything from MX5's and Mazda Familia GTR's to all models of GTR Skylines..... give us a call on 9647 1326 to dicuss getting your car tuned
GRACER makes 510kw at all 4 with a link and it drives perfectly so they cant be that bad :):) We (Advan) use heaps of them.... we have about 15 of them getting about Sydney now installed in everything from MX5's and Mazda Familia GTR's to all models of GTR Skylines..... give us a call on 9647 1326 to dicuss getting your car tuned
heheh I knew there were more features, thanks for adding them. Our tuner in mackay loves them.
Apexi PowerFc Standards are just an easy way to make a bit of power, you want to make alot, and have the tunability, get a link, or something different.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
