Credit is fine I'm happy for him!!
I think the problem is he posted photos that show us nothing. Which means - if he posted saying he's happy with no photos ... everyone would say something on the lines of "YAY we're happy too!".
Since the photos got put up, everyone expects specs and photos now because the point of the thread isn't "yay I'm happy" but "yay I'm happy checkout my car"... which just isn't possible.
Either way ... BOOOOOOSSST!!! :aroused: :)
https://www.sau.com.au/forums/topic/80086-finally-finished/#findComment-1465842
i think you will all find he will post better pics and a dyno graph very soon
but its no bullshit this car is awesome i have seen it with my own eyes and seen the dyno sheet.
everyone who is whinging will be eating their words.
also as if cops don't check this sit out so posting exactly what is done to you car can be dangerous.
https://www.sau.com.au/forums/topic/80086-finally-finished/#findComment-1465929
depends..
I personaly make my car street legal and could brag about it all day
HAHHAHAHAHAHAHA you guys are such skeptics YES I will send more day photos and sorry thie pics didnt come out too good BUT when I prove it to you doubting thomas' and I want a BIG APOLOGY!!!!! I dont care what you guys think I KNOW IT IS BALLISTIC AND THATS ALL I CARE about.
https://www.sau.com.au/forums/topic/80086-finally-finished/#findComment-1465952
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
