Hey guys, well im waiting for my new muffler for my old school HZ GTS Monaro, the old was is completely rusted out on the inside, causing a massive choke in the system, not good for a car whatsoever. Anyways, after painstakingly taking it off, ive decided it should always be off, if only for the law. The thump the thing makes is almost frightening, for a lightly modified 5litre.
Anyways, i think ill grab a sound bite and post it up here. Just for those who appreciate other sorts of cars.
https://www.sau.com.au/forums/topic/80170-the-big-v8-rumble/
Mate I know what you mean.
I had a 351 with err.. fake .. twin pipes.. Basically they ended up at the end of the car but really a lot of the exhaust came out the side (side pipes basically) and that thing sounded AWESOME. At idle, on the pedal a little, on the pedal alot - it just sounded great.
I hope it gives you that little bit of reverb at the back of your throat/lungs as only a big v8 can :aroused:
When you get the sound bite if it doesn't sound like it's picking up the boomy v8 sound try moving away a little so less of the high range is picked up and more of the bass notes come through :cheers:
haha, alot of cars do sound nice, each to their own, each engine has its own unique note, ie, ford and holden 5litres have different notes. :)
Anyways, i dont wanna piss off the neighours atm, and ive been flat out at work, but should get it recorded tomorrow :D
to tell you guys the truth, when i first drove the skyline, i was scared to rev it because i was used to the sound of a v8 and i felt as if the rb20det at high revs wasn't a very healthy sound. but now i'm used to it, and i like it, and have no trouble giving it some :)
When you get the sound bite if it doesn't sound like it's picking up the boomy v8 sound try moving away a little so less of the high range is picked up and more of the bass notes come through :)
It's an art, isn't it? I've never been able to get a decent recording of an exhaust note that didn't sound like it was underwater, or tinny.
bf is trading his xr6t in this weekend...for a GT..
as much as he loves the turbo he really wants to get back into a V8..
i think some people just love the V8 rumble. I'll turn my head for any car that's got a nice sound to it really...but the sound of an RB always stands out ;):D
get one stock vn group a ss and install a vortech supercharger and listen, trust me... puree horn, i had a few turbo mates come around saying oh the rb26 sounds awesome and v8s r no where near as good, until i started my old mans vn group a with the blower and they where drooling and wanting to take photos under the bonnet and shit haha, 2 min prior they didnt even look twice at it, but they sure noticed the rumble of the beast :whackit:
i reckon most v8s sound shit but injected and blown are bloody awesome ;)
still rate the rb26 very highly of course
cheers
Brad
the v8 has never done anything for me. although i like the sound of the current Ferrari's.
much prefer the sound of turbo or F1. love hearing the v10's at 18,000 + revs. just crazy.
don't mind the Porsche 911. Much angrier than what i expected from a boxer 3.6 or 3.8 litre
very un Aussie i know.
Cheers
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
