Just a question regarding reliability as I am an ex-Commodore owner and they are probably the most unreliable cars I have ever owned. I moved up to a Skyline after owning several HSV's and V8 Commodores because I loved the style, power and quality of the R33's. So far my Skyline has been very reliable with none of the rattles or squeeks that I had in my Commodores and only basic things needing to be replaced as you would expect from a 10 year old car (fuses, globes, brake pads, clutch etc). How has your Skyline served you so far?
https://www.sau.com.au/forums/topic/81099-how-reliable-is-your-skyline/
had the car for a month then the coilpacks started to die, its a given though since r34s are known for their coilpack failures. other than that the skyline is alot better than my old commodores, however the supra seemed to have a slightly better motor, ran silky smooth, the nissan motors are a little noiser.
Coils do die but once replaced you can forget them.
They are very reliable unmodified but you can show up slightly weaker area with modification. The same is true for any car.
They don't get the dodgy squeaks and rattles, bad door closing/openings and stuff so much though so that is good.
Turbo died while having new exhaust fitted. Solution, upgrade to 460hp turbo with ecu and fuel support.
Clutch died with new turbo. Not built to handle 400hp. Got a heavy duty one put on.
Since in both cases I was able to upgrade, theoretically no money was wasted.
Everything else is great. I love my Skyline :)
I've only had skylines over the last 5 years.. 2x R31, 1xHR31 (only for a few months), R33 GTS-T, and R32 GTS-T
Biggest problem was a crank angle sensor on my first R31.. and fuel pump on my current R32 (fuel pump was installed by me though and was aftermarket)..
Other than that, absolutely nothing. Pretty amazing, and why I've always bought Skylines :)
Only problem i've had was the stock fuel pump being basically dead, and the car running lean (not dangerously, but defintely on the way to getting there). Replaced that and so far it runs fine. I actually went a skyline over other imports/turbo cars in hope to get great reliablity, as I always drive my cars reasonably hard.
yeh im currently a ford bogan. yeh laught at me. i know i was an idiot for buyin the dumb thing in the first place. i was wondering how the skyline would be reliability wise with all the high revving n lots of boost etc. but you guys seem to rate them alright. cant wait to get mine. how do they handle flat changes? or dont they?
yeh im currently a ford bogan. i was wondering how the skyline would be reliability wise with all the high revving n lots of boost etc. QUOTE]
I dont own a skyline either mate but in regards to the (high reving) fest i asked my old man something similar and its not like the typical ford or holden engine... These are a performance engine so take alot more then f and h.
Even with my vl being the RB30 after a while of me really giving her a beating it drastically started to lose power but that wasent so much the engine it was really most things dying around it.
Mine's been perfect for a yeah in mostly stock form (changed turbo back zorst and cold air box). Had an issue with the fuel gauge reading empty way to early but it fixed itself and hasnt occurred since.
  • 1 year later...
Man I have had my car for six years when they were'nt soo popular and have never had any problems no oil leaks the car is damn strong. :happy:
1 motor 1 clutch and a couple of engine mount in my car but dare say motor was my own fault after putting the boost on 10 and not being tuned but all in all car cost me 16 owes me 21 after the motor and stuff and looks no better than day one haha but i still love it for the price what goes,handles and stops like 1 not much other than that its been great and pretty reliable other than my little mishap caused by myself
mine's been very reliable *knock on wood* and besides the normal services, its needed nothing.
one thing i noticed is the rb's are balanced pretty damn well. probably why they can take high revs/hard driving without issues. u can sit a glass of water on the motor while its idling and it hardly moves. try that on a commodore.
if ur going to push it hard...just make sure you look after your oil (restrictors, increased sump capacity and baffles) and you should be right to go... that's all i am aware of being a consistent issue if you are going to push it really hard (by the sounds of it you plan on thrashing it...excuse me if i am wrong)
...meh
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
