you'll get alot of opinions on this, personally i think there an awsome car, but the shape etc aren't for everyone.
the reason alot are under 100,000kms ( this is what i've been told anyways ), is because japan has stricter emition laws etc than here, so they have to get rid of the cars they have after a certain amount of k's and get something that is newer ( rezz or someone in japan that knows the real reason care to clarify ??? ).
they only really drink alot of fuel if you drive like 150km's everywhere or do alot of city driving ( stop starting at lights etc all the time ), you get roughly 400kms from a full tank ( i do anyways ).
hope that helps :)
https://www.sau.com.au/forums/topic/81167-skyline-question/#findComment-1475190
R33's are great cars and yes I have heard of speedo's being wound back but I personally wouldn't worry about this. Most Japanese people don't do a lot of driving and as stated, as the car gets older the costs go up. Rego, tax and also servicing goes up dramatically as the Japanese laws state that even slightly worn parts must be replaced so it's actually cheaper to buy a new car than it is to constantly repair an old one. Get an R33 and you won't be dissapointed but make sure you look at a lot of cars and drive them all so you find the best one out there.
https://www.sau.com.au/forums/topic/81167-skyline-question/#findComment-1475484
Its not in australia, only Japan. Once a japanese car gets over three years old, the yearly taxes and fees rise dramatically each year. Service costs are also huge. That why there are so many imports here, south africa, new zealand, because the older the car, the harder it is to get rid of in japan, but much easier to ofload to us. That is why they are low kay, and generally in very good condition. You can get a preservation - or historical significance attached to a limited build car in japan ie: HR31 GTS-r or R32/33/34 GTR, and this helps to keep the cars there, but not for long, they generally find their way somewhere else.
https://www.sau.com.au/forums/topic/81167-skyline-question/#findComment-1475527
try to avoid the thrashed ones owned by some youngsters, who have lost there driving license and had to sell their line, for example.--------These cars generally come standard as "stuffed".
By straight from Japan, if you can, or from a reputable seller who will register the car for the first time in Oz. !! Odo's are crap.....get any car visually pre-checked.
Or buy mine!! (5uckin' fussy older owner!!)
By the way, I know some fantastic '18 year old drivers''!!!!!!
https://www.sau.com.au/forums/topic/81167-skyline-question/#findComment-1477235
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
