Hey all,
The other night (private roads of course) I was pushing my car (s14)
I noticed that in 3rd gear at 5k rpm it sempt to no longer really accelerate.
It sempt like it wouldnt go any faster, what could this be?
note: car is stock therefore boost problems shouldnt really be existent.
Is there anything that I can do to make it more efficient at higher engine speeds?
https://www.sau.com.au/forums/topic/81257-why-is-my-car-holding-back/
Dee 33 It kind of felt like the extra revs werent giving any power. It was sitting at 5k rpm (and wouldnt go any higher) going up a hill at 140 in 3rd gear, so MAYBE it was to do with the slope.
I didn't put it in 4th because there wasnt enough room to safely slow down
Its the local 200sx s14, not the jap one
Abo bob Yep, the whole car is stock - I dont know whether to do it up (with and exhuast and boost controller) as it costs $$$$ to do properly.
Is it worth chucking on a 3inch turbo back? and getting an electronic boost controller?
i had this problem in my car a while back(s13) but it was in several gears...
i changed the clutch, cleaned the pod filter works fine....
if it only happens at a certain speed..then its prolly a limiteror other reason
breathing and boost restrictions usually happen at the same rmp, through different gears
I was testing my newly arrived R32 GTR the other night, also on private roads by chance(maybe we were on the same road ;) )
I had no such problems thats for sure, 3rd revved out nicely, as did 4th. Come to think of it, I think 5th gave a good showing as well. What limiter?
What kind of hill are we talking about? A slight rise, or a mountain pass? You could just be at the limit of your cars pulling capabilities.
With regards to the mods to your car, they are two of the best mods you can do to any turbo car. Have a look around, you'll be able to find plenty of suppliers on the forums, both local and importers to provide such mods.
the problem is you only got a 2 litre donk...... nah just kidding,
give the car some good tlc and eliminate the obvious things off your list like, oil change, clean pod filter etc etc..... once the simple things have been checked and it's still giving you problems, then it's time to head to a mechanic, unless your mechanically inclined....
thats what i would be guessing, aren't sr20's low revving engines? I haven't driven many, but thats what i'm thinking
i'd say if you wanted it be pulling still at those revs then you should've bought a skyline, feel free to correct me if i'm wrong though
my thoughts: if it's a stock car you probably just ran out of breath - swap the exhaust at least and the filter for a high flow panel or a pod? how steep was the hill. if you were going up a fairly decent hill than you would've been putting more of a load on the engine than if you were cruising along a flat stretch of road.
Its a hill that climbs for a good kilometer or two.
It starts at the bottom of a valley, so initially its quite steep and it takes ages to be back on flat land. I started hitting 5k rpm when it was about halfway from being back on flatness. It was really weird because it wouldnt rev any further but was nowhere near the limiter
I was driving normally down the valley, once i got to the bottom, I chucked it into fourth and it started boosting a bit, so i thought sweet, chucked it 3rd, it launched for a bit, once it got to 140 it wouldnt go anymore
so it had only been under boost for about a minute max before it started to hold back
I have seen this before on a dyno, problem found to be a boost leak
I dont know if it could be a boost leak, I take care of my car, then again you could be right. I change the oil every 5000, and then a mechanic looks at it all over and tells me any problems, the gaskets of the turbo were replaced but it shouldnt be leaking now. However, mechanics can be scams
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
