I have a mate who is selling a garret GT30r interally wastegated turbo. it has a .63 exhaust housing .7 front and a 560hp rating. I was wondering what power this would make and how laggy it would be on a rb25 that has fmic, powerfc, fuel pump and 550cc injetors as i am thinking about buying it.
thanks
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/
thanks
I'm about to do the exact same thing
I have 96 model with fmic, full exhaust, intake, PowerFC, Fuel pump
Just got a VG30 exhaust housing (.63) to put on a brand new GT30 Compressor and core.
Should be at full boost at about 3500rpm.
All I need is injectors.
What kind of injectors do you have? Are they high or low impedance?
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1476900
need more info is it modded internal...?
if not 560hp turbo on a rb25det will be very laggy!  "est boost at 5-6rpm maybe".
a GT30 with a .63 rear housing will be on by 4000rpm
My advice would be aim for a .82 rear as a .63 will make it very "snappy" comnig onto boost which isnt good for traction
Matt, why do you have an RB25 :confused:
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1478856
I had a GT30 o.82 rear on an RB20 and it had full boost by 4200rpm. Boost by 5 or 6 is bullshit. Id give the 0.63 a miss and go the 0.82; it'd be well suited to an RB25
saun- what mods do you have? my gt30 has a .63 rear and my rb20 doesn't have full boost that early
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1480949
hey guys im also about to slap one onto my r33, i was told that it wouldnt be too laggy, about 4000rpm full boost.
if you think 4000 is too laggy... wow...
Mine with a .82 rear is all on by 4200. Stock head that is.
Still have nearly 4000rpm worth to use.
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1481207
if its any help ive got one on my rb25 , starts making boost from2300/2500rpm and full boost by 3500rpm. so probably add another 500rpm for rb20 maybe.
Edit:
I have just read your gt30 thread.
.70 comp and .63 exhaust housing
That is why your making the power so early.For a moment there i thougt it was the .82 and i was wondering why you were making the power on average 500+rpm earlier than others with rb25.
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1481431
I had a Tial 35mm external wastegate plumbed into the modified standard manifold. Worked well too, but 0.63 would have been better on the RB20.
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1482181
it should kick in about 4500rpm and ive seen people get over 260rwkw with the mods you have
my friend has a standard internal rb25 making 343rwkw with a gt35r/106.
its a huge rear housing for a 2.5l engine but it makes 25psi by 4500rpm. i suspect the gt30 with .63 will be at 25 psi by about 3500rpm
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1482253
Thats got to be harsh on the stock internals....
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1482423
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
