I have a mate who is selling a garret GT30r interally wastegated turbo. it has a .63 exhaust housing .7 front and a 560hp rating. I was wondering what power this would make and how laggy it would be on a rb25 that has fmic, powerfc, fuel pump and 550cc injetors as i am thinking about buying it.
thanks
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/
thanks
I'm about to do the exact same thing
I have 96 model with fmic, full exhaust, intake, PowerFC, Fuel pump
Just got a VG30 exhaust housing (.63) to put on a brand new GT30 Compressor and core.
Should be at full boost at about 3500rpm.
All I need is injectors.
What kind of injectors do you have? Are they high or low impedance?
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1476900
need more info is it modded internal...?
if not 560hp turbo on a rb25det will be very laggy!  "est boost at 5-6rpm maybe".
a GT30 with a .63 rear housing will be on by 4000rpm
My advice would be aim for a .82 rear as a .63 will make it very "snappy" comnig onto boost which isnt good for traction
Matt, why do you have an RB25 :confused:
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1478856
I had a GT30 o.82 rear on an RB20 and it had full boost by 4200rpm. Boost by 5 or 6 is bullshit. Id give the 0.63 a miss and go the 0.82; it'd be well suited to an RB25
saun- what mods do you have? my gt30 has a .63 rear and my rb20 doesn't have full boost that early
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1480949
hey guys im also about to slap one onto my r33, i was told that it wouldnt be too laggy, about 4000rpm full boost.
if you think 4000 is too laggy... wow...
Mine with a .82 rear is all on by 4200. Stock head that is.
Still have nearly 4000rpm worth to use.
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1481207
if its any help ive got one on my rb25 , starts making boost from2300/2500rpm and full boost by 3500rpm. so probably add another 500rpm for rb20 maybe.
Edit:
I have just read your gt30 thread.
.70 comp and .63 exhaust housing
That is why your making the power so early.For a moment there i thougt it was the .82 and i was wondering why you were making the power on average 500+rpm earlier than others with rb25.
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1481431
I had a Tial 35mm external wastegate plumbed into the modified standard manifold. Worked well too, but 0.63 would have been better on the RB20.
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1482181
it should kick in about 4500rpm and ive seen people get over 260rwkw with the mods you have
my friend has a standard internal rb25 making 343rwkw with a gt35r/106.
its a huge rear housing for a 2.5l engine but it makes 25psi by 4500rpm. i suspect the gt30 with .63 will be at 25 psi by about 3500rpm
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1482253
Thats got to be harsh on the stock internals....
https://www.sau.com.au/forums/topic/81287-gt30r-on-rb25det/#findComment-1482423
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
