Greetings
I am just about to INVEST in another Skyline. This time I will be returning to the Skyline community with a R33 GTR as my weapon of choice. The car im looking at is a Purple GTR R33 and Im looking to get some personalised plates put on it straight away because I cant have the plates that are on it because the current owner would like to retain them.
I was wondering if you guys could help come up with some awesome personalised plates for me.... So far I have thought of: -
VILENT
EVL GTR
EVL R33 <-- I think thats taken
IM FAST
and a few others that I cant think of just at the moment.
Thanks guys
https://www.sau.com.au/forums/topic/81375-personalised-plates/
They're like $300 aren't they?
I really don't see the point in paying that much and getting the extra attention when you can get normal plates for $30 and blend in.
I was going to get slimlines with only 3 or 4 letters so it's a lot smaller so I don't have to bend the the normal size plates, but I figured it's better off just to bend the normal ones and spend that $270 on something else.
Golgo is the codename of a Japanese assassin character from a manga series (and a few movies and animes) - He's the guy in my avatar.
Basically a badass guy who kills people and maks chicks all day.
Just like me :P
BTW: Golgo IS for sale if you are wanting a Purple 33 R...
lol @ jamezilla tryna get anyone and everyone to buy the gtr.
nah personalised plates are good i reckon, after i get my car back from its spray job im gonna get me some, so far ive thought of:
AWYEAH
MYOMEN
UH-HUH
2SXXXC
not sure how many of them are taken already but i'll soon find out once i get my ass down to vicroads :P
Its a GTR from one of my dads friends. He was involved with bringing the 100 GTR R32's into australia back in 1992. The car is a 1997 GTR, 18inch wheels and a few extra goodies. Very nice car, hardly driven in the last 4 years he has owned it and I am picking it up at a cheap price aswell.
1. Personalised plates
2. Visiting race pace for some of Ben's magic
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
