Hi All,
Clutch has apparently died in my R32 GT-R so its time to do a switcheroo. Whilst its all apart it might be worthwhile adding a lightened flywheel.
So does anyone have a lightened flywheel for an R32 GT-R (1989 model: can never remember if they are push or pull) sitting around that they want to sell? Alternatively, does if anyone knows of some good deals lemme know.
Lucien.
https://www.sau.com.au/forums/topic/81597-r32-gt-r-flywheel/
Push or pull doesn't matter to the flywheel but for reference the 89 should be a push clutch.
We can supply a brand new Fidanza flywheel which is l/weight ( approx 4.5kg ) alloy with a replaceable steel insert.
It is also a pretty purple and is $660 incl plus freight
Cheers
ken
lucien have you driven a car with a light flywheel on the road? the reduction in torque at low revs is noticable.....
High duncan,
No, I have not had the pleasure, I have only read other people's experiences (which are overwhelmingly positive, but you wouldn't expect them to be too critical of their decision having just shelled out $500+ :huh:).
Does the faster revving, in your experience, mitigate some of the torque loss at low revs? Not worth the tradeoff?
  • 2 months later...
I'm in the same situation at the moment.. clutch needs replacing 'cause it's stuffed and I'm thinking about doing the lightened flywheel at the same time.
Since the car is a daily driver more than anything else I really didn't want to go under 5kg. UAS have one at 6kg but I called them up today and they said they won't have any for a few months (at best).
I can't be bothered waiting that long so I'm considering the option of just machining the stock one down a bit.. maybe shave off a kilo or so. Don't really know what a safe limit is but I'll get someone that knows what they're doing to do it.
Anyone else have their opinions on this?
I bough the car with a stock flywheel in, and changed to a lightened one, got sick of it. As Duncan says driving around town its annoying. Anything under 2,000rpm and my car would shudder... I changed back to a stock flywheel and am glad i did. Car is much nicer to drive with the stock flywheel.
I never noticed a speed increase in reving, but that would probably because i fitted a twinplate with my lightened flywheel, so the twin plate+lightened flywheel probably weighed the same as the single+stock flywheel.
My advice? Save your money, keep the stock flywheel (get it machined if it needs it obviously). Jim Berry told me the same thing - said the Japs usualy get it right with thier flywheels, they are a good weight. Being turbo cars we need to keep the rpm spooling, if it was a torque monstor down low, then maybe consider a lightened flywheel.
Hope this helps.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
