after a fair bit of money spent this is how a project is going after an engine shitting itself and being rebuilt
rb20det
polished
balanced
o-ringed
arias pistons - taken out 20 tho
better valve springs
had the head machined
copper head gaskets
billent adjustable cam gears going in
oil catch can
high mount exhaust manifold
to4e turbo
700x300x78 fmic 3" piping
38mm wastegate
pod filter
bosch 040 fuel pump- might change
3" turbo back exhaust
wolf 3d series 4 ecu
with this set up wat kinda power can be expected? any suggestions on anthing missed? there has been alot of money spent so far as you can see on the list, any help would be greatly appreciated
https://www.sau.com.au/forums/topic/81870-how-much-kw-will-it-get/
These arent really recommendations , more like questions:)
Any reason why you put valve springs in but kept the std cams?
Also it may have been worthwhile to go a lot bigger then 20 thou, you could have easily bumped up displacement to 2.2L with pistons alone.
Also what have you done in the way of rod bolts for the std rods?
Also i wouldnt decompress the engine any more then the std 8.5:1, also i noticed of late some of the cheaper 3" exhausts are in fact 3" ie 76.2OD whilst a lot of the Jap so called 3" exhausts are actually 80mm...
gtr injectors,and yeah-the to4 will b good for 1.5 bar, yeah got cam gears,std camshaft. he will be changing other things over time. "Also what have you done in the way of rod bolts for the std rods?" umm nothing i know of, any advice would be greatfull though, just need to know what else is necessary, rods? crankshaft?
To4e? why are people using OLD t04's when there is a shitload of new range turbo's out that spool earlier and produve a much nicer power band :)
sadly enough tho with the money spent on that you could have dropped in a rb25 given it a power fc turbo upgrade with injectors.. and it would probaly go alot harder and easier to drive than the dirty old t04e
yeah, mate, you should do that, it would be really good :)
he wanted a powerfull rb20, he now has a powerfull rb20.
you would be surprised how much money was actually spent.
Either way, were you going to give some advice? thats why we started this thread.
oh- and the to4 is new or...hasnt been used.
is there anything that he could have missed? thx guys.
I put an RB25 into my 32 and was rapped, originaly i wanted to build my 20 and have a crazy 20 but when it came to spending the bucks Ben from Racepace advised me that the 25 will make a bit more power at the end of the day so i was sold. I ended up doing the forged pistons, gtr rods, tomei cams 550cc injectors, power fc, hks 3037 proS, fmic and 3.5inch exaust. very happy with the job that was done going to make about 280kw at the wheels on about 17-18pnds.
could'nt be happier with the turbo choice. Perfect for the street not laggy at all.
I wanted to do the same thing.. get a powerful rb20 in my silvia.. but how ever with the money that i was goin to spend i was better off just buying a 26 and getting similar power out of a stock rb26 with mild upgrades.. and still have a safe reliable engine..
dont get me wrong.. rb20's are awesome little motors.. but they just dont have wat it takes to get alot of power out of
240 rwkw so far, highflowing the t04, not alot of power:P we will see how we go after its done
  • 1 month later...
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
