I can get 5+ AP engineering power fc to suit R32 GTST for only $1150 delivered each.
This price doesnt include the hand controller.
If you require the hand controller then the total price is $1470 delivered.
**price change**
** with commander - $1380 delivered **
** without commander - 1040 delivered **
Come with 12 month warranty
Close date - 26/08/05
Payment due - 30/08/05
Buyers
1/ JL
2/ grandmasterb
3/
4/
5/
Edited by gR33ddy
https://www.sau.com.au/forums/topic/81906-r32-gtst-ap-power-fc-group-buy2/
Have you found a cheaper deal? I havent :D
YES mate as i said in my email to you a while ago, i bought it without HC for $1000 and after talking to the supplier in Japan he said that if you guys were getting more than 10 peeps then thats the sort of price we should be getting for the AP Engineered Power FC.
Dont get me wrong the price you are offering is still very good, but you look at the difference with HC and then without and you can buy the HC for less than the difference in the GB if you know who to talk to.
My 2cents and im not dissing the GB on you Paul, as i said i still maybe keen for one without the HC but will see in time.
Cheers B
why would you buy another one if you've already got one? :confused:
Feel free to forward me your suppliers details and I'll be more than happy to bring the prices down.
Had most of new gear stolen when my place got broken into Paul.
Therefore have to buy new gear and the Power FC happens to be one of those items.
The cheapest i have found without HC was $1050 delievered.
And thats normal price with no GB or anything <_<
I will see if he has no objections to me passing on his details and will forwards them onto you if you like???
Cheers B
Cheers B
Ok, far enough.
If I can get offer these for a better price then I am sure the other interested buyers wont object.
:cheers:
Ok, far enough.
Sent him an email and waiting to hear back from hom.
Let you know when i do ;)
Cheers B
Hey Guys,
I'm just curious in finding out what use the hand controller is to me??
If I buy a power fc, it will go to TillBrooks for installation and tuning, and I'm sure they have the products to be able to tune it and set it up, So what use would the hand controller be to me,
What functions does it display??
Do I need it??
Thanks for your helps guys.
Greg
Hey Guys,
Do I need it??
Greg
Well assuming that the tuner your going to has a HC that will work on your unit then there is no real need for one.
The only time it is of use if you are tuing the car, other than that then you shouldn't really be playing around with it at all.
Cheers B
RAZOR32 - Your not too late. We dont have enough buyers at the moment for the group buy to go ahead.
I'll extend the finish time and see if we can pick up some more.
I guess anyone who is interested is waiting to see if we can get a better deal from grandmasterb's supplier.
Ok guys the best i can get out of him for you all is $1040 without the HC which is still a lot less than most people are selling them for at the moment.
For all you that are interested in the Power FC with the HC i'll let you know ASAP as he's going to get back to me.
Pau llet me know what you want to do with this???
Cheers B :D
Cheers B :)
Ok so the best price i can get for all interested in Power FC with the HC would be $1380 :angry:
Cheers B
PS: PAUL i dont mean to bastardise your thread and feel free to have the posts deleted at anytime as im not trying to take over your GB, just trying to get the best prices for anyone and everyone, so if i am over stepping the mark then feel free to tell me ;)
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
