Hi all, just want to know from those who have Apexi Gt radiator cap, oil cap....ect..on their car, do they really work?
  For instance the Apexi Gt radiator cap, it said to hold up to 1.3 kg of pressure and help raise boiling point...ect... Is it real?
Yes for the radiator cap and the oil cap still stops the oil from coming out.
The oil cap won't offer any benifits however the radiator cap will under race conditions or heavy traffic.
The only problem with a higher pressure rad cap is that you will be much more likely to blow radiator hoses.
Well I have noticed a big difference going from a shagged cap to a decent one.. it can make what seems like an inefficient radiator perfectly fine.
The usual brassy coloured ones you seem to find in australia seems to pretty reasonable quality though.. I guess because the big cars in Australia are designed to run under high outback heat..
case in point...
on RHS is my old stock R33 cap.. (painted by me ricer red, ignore that).
on the LHS is your generic $10 one from any parts place now on my 32. Note the thicker top pressure seal, and how the rubber comes over the top of the cap.
I am not sure whether the stock GTR one is anything the same, but its not hard to improve on the standard design..
Anybody have a picture of a Greddy/Apexi/probably overpriced ricer one to compare?
case in point...
the pink one in your picture has had parts of the rubber seal break off. it wasn't like that when in good condition.
West,
Have you got a 'real' temperature guage to determine if the car is getting hot or not?
The stock temp guage is a 3 stage. Its either cold in the middle or hot.
For example the temperature range in the middle is from 72degree's right up to 102degree's from memory.
102degree's I would consider to be too hot, especially if it is reaching these temps on the street. On the track sure, lap after lap on a stock cooling system will see these temps but definitely not on the street.
West,
I would say 100 is too hot any time. on the GTR the water temp never gets above 83 degrees on the track, that's including 10 lap race when pushing very hard (too hard!). that's with stock radiator and a cusco cap. car is making 250kw atrw but does run a big oil cooler which would help. for me 90 i reckon is too high.
my GTR with oil cooler hit 105 water temp at the track on a 35degree day...
fatter radiator methinks :D
Also, gordo - while the rubber lip might make a small difference, the only thing affecting the rad cap from opening is the spring - higher spring force, higher pressure to open :D so all the aftermarket 'high pressure' caps have are a stiffer spring... much like an aftermarket wastegate actuator :)
holy sh1t mate. 105 is pretty well up there. may i ask where is the oil cooler mounted? i haven't pounded it on a 35 degree day though either so that would certainly make a difference.
The cooler is in the duct in the front bar passenger side. It is poorly placed, so we're going to go at the bar with a dremel... might also put in an exit duct in the side of the front bar ala Nismo style
yeah mine is in the passenger duct also, but with an aluminium duct built around it to duct all the air through the core, and with an exit duct in front of the wheel.
what kind of oil temps were you getting on that day?
yeah I would say that was helping drag up the water temp a bit too. i guess they both feed off each other to a degree and once they start to go up it's a bad cycle. having done a few track days this year and even a 10 lap race (including comp pitstop etc) i haven't got oil temp over 95 and water temp never over 83. i think the duct and giving the air an escape will help a lot.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
