fitted rear r32 gtr discs, rebuilt calipers (with speed bleeders) and r32 gtr (front) braided brakeline
fittted front r32 gtr rebuilt calipers, cpz bracket, 324x30mm 350z track rotors drilled, with stagea (front) braided brakeline
pads are qfma1rm all round
mags needed to clear are 18x8.5"
on the r32 track car Im putting on the stagea rear rotors, stagea rear braided line, stagea rear calipers & pads
on the front goes the wilwood superlite calipers & matching braided brakeline & pads, plus a new set of dba 4000 rotors Ive got sitting here
Dixcel Part No.'s for Series 2 Discs WGNC34.
I'd be pretty sure they be straight swap, OD/Offset/Thickness same.
PD-Normal Disc
SD-Slotted Disc
HD-Heat Treated Disc
HS-Heat Treated Slotted Disc
The rrp price is there too converted from yen (currently 76.6)
DIXCEL 98/8~01/12 WGNC34
Front Part No. 321 2013
pd 218.41
sd 327.62
hd 341.16
hs 450.34
Rear Part No. 325 2018
pd 218.41
sd 300.23
hd 354.81
hs 453.99
is that per rotor or per pair (assume pair)?
can anyone confirm whether brakes are the same between RS Four and RS Four S (i would assume so)?
actually, according to the Dixcel website, i believe the part numbers are (for S2 C34):
FRONT - 321 2013
REAR - 325 2016
(as opposed to 325 2018)
i am sourcing pricing from japanparts, and will pass on the details
apparently all S2 are the same, but S1 are different
for S1 C34, i believe the part numbers are:
FRONT - 321 2019
REAR - 325 2018
cheers
Edited by Stooge007
*** Series 2 Stagea Pads now back in to stock ***
Apologies to all those that have been waiting patiently on the back order list, we now have stock of the S2 Stagea pads to suit both street and track.
Front HPX $119
Rear HPX $79
Front A1RM $179
Rear A1RM $179
- HPX is a Bendix Ultimate/EBC Green/Project Mu B Spec equivalent performance street pad.
- A1RM is a Bendix SRT/Ferodo DS2500/Project Mu HC+ equivalent street/track cross over pad.
Any questions, or to order, just swing me a PM, or give us a bell on 1300 884 836. Free shipping when you order front and rear together, or else $8 per axle set individually.
Regards,
Greg
Fitted some RDA954S rotors and some Greenstuff pads on the weekend.
The RDA954 rotors definitely fit s2 RS4V, anyone having fitment problems, make sure the calliper is clear of the rotor (use a screwdriver for leverage, make sure the rotor is nipped up with a wheel nut so it is held tight) before tightening the calliper bolts.
actual dimensions for ROTORS series 2 1999 rs4s
FRONT -
diameter 290mm
height 48mm
centre 68mm
minimum thickness 26mm
brand new thickness 28mm
REAR -
diameter 292mm
height 63mm
centre 68mm
minimum thickness 16mm ( couldnt remember exactly what measurement was here but pretty sure this was it could be 14)
brand new thickness 18mm ( couldnt remember exactly what measurement was here but pretty sure this was it could be 16)
so far from my searches nothing is exactly the same.
and from what i could see on dixcel japan website is that there are 4 or more different type of rotors between series 1 and 2 some going right through all models so it is possible that some suggestions that have been posted will work on some cars and for others it wont so make sure u do ur research b4 u buy or take some of the advice on here
If series 2 RS4S is the same as series 2 RS4V, then the 350Z rotors will fit.
i have had it at a brake specialists for the last 2 days and they said they will not be right 1st major difference is the thickness of the rotor od is out and height is slightly out on the 954s rotor
BUBBA just let them get on with it,
CAN`T HELP SOME so let him get fed BULLSHIT
Whatever you want to get fed is up to you, I fitted them on the weekend.
Agreed, I'm over it.
Anyone found a solution for dogbones to fit 324mm GTR rotors yet? :cool:
With 33gtst/32R calipers yes, I have a solution that *should* work but haven't tried it yet. I have a set of dogbones that fit on non-4wd front hubs but they hit the lower ball joint on 4wd hubs. I have another set that are supposedly off a z32 that offset the caliper as opposed to the other ones which rotate it.
With stock calipers, not yet as I need to solve the offset issue.
Edited by bubba
meh...
must have been the small print on screen.
here's a screen capture for all to refer to.
FRONT - 321 2013
REAR - 325 2016
FRONT - 321 2019
REAR - 325 2018
cheers
** S1 Stagea Pads Now In Stock!!! **
Hi all, we've just received our long awaited first shipment of QFM Performance Pads to suit S1 Stagea!!! Available in both compounds, QFM HPX (Bendix Ultimate equivalent, fast street) and QFM A1RM (Ferodo DS2500 equivalent, fast street and track). Prices as follows:
HPX Fronts $119
HPX Rear $119
A1RM Fronts $179
A1RM Rear $179
Shipping is free when you order front and rear pads together, or else $8 per axle set individually!
Any questions at all just let me know!
Regards,
Greg
Fitted up new front slotted rotors with new pads today and if it doesn't rain tomorrow I will fit new rear slotted rotors and pads then bleed brakes allround.
Which rotors did you use on the front, RDA 954S? I've had my set machined down and will be fitting them tomorrow.
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
