  • Replies 108
accusump is a waste of time/money. actually i don't know that for a fact, just srpouting crap other people have told me. they do know what they are on about though so i usualy listen.
i reckon go the dry sump if standard + baffles is not doing the job (also providing it's legal for your class GTR Geoff).
We were just running the trust sump extension with baffles nothing special obviously :) But I can only blame the engine builder, I guess I can drive better than I build engines lol
Bec unfortunately I don't think either round is on TV :) but I will post up if they are :ph34r:
I think it's all just Sydney Sump Baffle Syndrome (SSBS) or the local builders up there :D
I've heard some good things about the Accusump and at about $1k seems comparably priced to a good sump job with the added benefit of low pressure detection and activation and a warning system. Portable to any car as well so worthy of thought. Our top lapper in Qld is running it as well but has never had it activate so either is soft or the track simply doesn't require it..........
I'm not racing a particular class right now but intend to once in Brisbane. I guess it won't be in a Skyline though due to the limited racing available.
I think it's all just Sydney Sump Baffle Syndrome (SSBS) or the local builders up there :rolleyes:
yeah can't argue with that. the folk up this way do seem to fear the SBS a lot. I have had the GTR out on Oran Park GP (a few times) and Eastern Creek without baffles (well as far as i know, they could be there i guess). but having said that i just last week bought a set of tomei baffles.
yeah, my only criticism of the accusump is that it's reactive in that it will activate when it detects low pressure, but by then it may be too late. it only takes a split second from what i hear to do some nasty damage.
Troy, lol at count hardcore...i like it. Yeah, dry sump is probably not for me, the sump baffles were only a couple of hundred, the bitch is putting them in. dry sump system i guess would way about the same as a accusump. though i guess some weight would be in the extra oil you would be carrying.
I think it's all just Sydney Sump Baffle Syndrome (SSBS) or the local builders up there :(
Honestly I think it is the ciruits, Oran Park and Eastern Creek are far harder on oil surge than Sandown, and Wakefield is probably a bit harder than Winton due to the altitude change.
You may remember that red Commondoor at Sandown, it runs an Accusump.
Hi Roy, in total weight terms the dry sump set up weighs a little more, but it is much better for weight distribution. The 10 litres of oil is in the tank in the boot and we also mount the oil cooler, catch can and oil filter at the rear as well. All up it moves around 12kgs from the front to the rear. And that's a big advantage.
Plus we run a scavenge stage for the cylinder head, so dynamically there is far less oil up high as well. This improves the front CoG a bit. The removal of oil from the sump increases the horsepower as the crank is not hitting oily mist. Not to mention the negative sump pressure from running excessive scavenge (in total terms), that gives as a few horsepower as well.
I would trade of the few kgs extra weight for those advantages every day.
:rolleyes: cheers :)
Agree with it all. So no dry setup on that barge..... Exxy engine to take the chance with so accusump must be alright then.
I believe it reacts to a sudden pressure drop before critical flow rates.
Wouldn't the Island be the hardest of all the tracks for oil surge? I know its a killer for fuel surge! Look at my front tyres from fuel surge at the Island (ABS failure due to engine cut from fuel surge and my consequent lack of skill)
But SBS still isn't an issue at the Island from what I've ever seen either. I still reckon you guys up there are just stuffing around with all the GTR's so that you can keep the GTST's looking quick! LOL
Oh no, Bathurst is far harder than Philip Island on oil surge because of the altitude changes.
You have to keep in mind that our GTR's (particularly the Production ones) are built to regulations, not "stick whatever you like on it". Plus Duncan spent a long time sucking hot air from Phil's GTR, not to mention the high speed spin when the brakes failed.
Oh, that reminds me.....did the engine run backwards during the spin Duncan?
:P cheers :D
For those of as not on the racing scene, what does that imply (ie. did the commondoor fail or ...)?
Oh no, it's a winner at Sandown, the track suits it, 2 drag strips joined by a wiggle. But he is coming up to Eastern Creek, so it will be interesting to see how it goes on something a little more technical.
:( cheers :)
Leanne will kick his butt :(
Undoubtedly, but it will be interesting see how Dave in the GTR gives him some hurry up. Plus we have a few more big horsepower cars up here that he won't blast past quite as easy. Should make for some good viewing on Speedweek.
:) cheers :)
Should get the rednecks charged up though, a VK crumpledoor with a V8SC donk
That's nothing, you should see the Foulcan with the 6 litre Sprintcar engine go :( , it's got another 100bhp on the Commondoor.
:) cheers :)
holy shit snowman. that's some nice flat spots you have there. more to the point though, please sell me your wheels... :(
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
