  • Replies 153
Posted Images
Abo Bob,
I have a couple of questions.
1. A CAMS L2S should be enough to negate the need for a wakefield Licence correct?
2. Can you have passangers on the day? My wife might come and wants to do a session or two.
3. Whats the cost for 1 car and 2 drivers?
4. Will we be having a seperate SAU group or just a mix?
Thanks
no. all you need is a roadworthy car. any car. hire car will do if yours is broken.
seriously you don't need it. try driving with hicas before you decide you don't like it.
Abo Bob,
Thanks
1. Yes
2. There are passenger sessions from midday onwards, every second one. Timed sessions no passengers.
3. Double
4. Mixed according to lap times.
lol hire cars work for me! twice now :)
hi duncan, ive noticed you comment about hire cars a couple of times, this interests me :)
i wanted to ask you, if you do happen to take a wrong exit and end up at a wakefield park track day in a hire car, is there any problem with using it? ie. do they check the rego to see its in your name when u sign up or it doesnt matter?
also which hire car do you reccommend, i always thought a manual mx5 would be best but lately noticed you can only get crap like convertible astras!
Very interested will know hopefully by tomorrow if i can make it...is there any spots left? plus im a member so its $130 right but what about a wakefield licence? im pretty sure its been over a year since i went so will i have to get another one? if so is it still $80?
Cheers
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
