probably cause it is cheaper and suits Christian more, you know to buy software for and host a forum isnt free and you dont pay for it........SO STOP WHINGING. Not being harsh just fair!!!
why does it say RB25DE under my avater ???
how do i change it?
its hard to find my way around,i gotta change colours
In your control panels under your profile - the first part custom name or something.
The new board doesn't look as nice as the old and I prefer the old layout but Prank has outlined his reasons on another post and they sound solid. Either way the usebase is here and that's what counts.. as long as we keep all the smilies :)
There are several threads in the wasteland on this..
Its heaps better, it just needs tweaking, which the mods are doing now..
They put fast reply back in, thats a good thing, Im happy
The rb25de thing is your rating on how may posts you have. when you have more that 500 (rb25det) you can change it.
Change it to the IPB default skin if you want the text to be bigger.
thank jebus..
so much better.
I suggest everyone try this skin...
although it kinda reminds me of nissansilvia.com but it's easier on the eyes..
and it's white instead of blue.
once the features of the vb forum is returned, (quick reply, smilies etc etc) this one should be quicker, and apparently with much more add ons.
I am getting used to it, and would like to congratulate the mods for doing this; a fresh, welcome upgrade
Yes i agree, The default skin is much better.
Sorry for being uneductaed in these sort of things but how do I use this default skin you guys speak of to make the text bigger? Because I am also having eye straining issues.
Thanks
EDIT~~ Found it. Thanks for the tip it is much easier on the eyes.
ok, to type this out for the hundredth time...
There were LOTS of behind the scenes problems with VB that were causing issues and creating excess work, upgrading didnt fix it and the vbulletin guys are still looking up what 'support' means in their dictionairy. IPB isnt cheaper, its more expensive and the new forums + blog feature cost Me $USD 245 (about $320 AUD) so I can assure you that it was done for good reason and not because I wanted a change or for any other personal reasons. IPB will be much faster and better overall and once everything is installed and running well you'll see that too.
Hope that helps people understand
Christian
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
