  • Replies 116
Anyone thinking about considering a location and time to meet so all the competitors can travel down at the same time? Only suggesting because it is a very very long trip to get down there and some of us aren't familar how to get to collie or where we are supposed to meet as well.
Maybe a meet point say at Maccas for breakfast and then heading down south all at the same time? Comments?
Im in for sure.
Alright well considering the response.. I might have a crack at trying to make a cruise and see how I go.
Closer to the date once I get more details I will post up a time but the meetpoint will be at Leach Hwy Macca's in Myaree as it is far enough south and close to the freeway onramps to make it an easy location for most people.
XRW, yep, got you down + 1 already.
Josh, at this stage, probably only one day. I did leave it open and book the whole weekend, but it seems most dont want the two days.
Without the numbers, it would get very expensive for people on the sunday, unfortuneately.
also is there a bp down there for ultimate? otherwise its jerry can time
The circuit is easy to find.
Drive through Collie (Towards Darkan) and keep going until you will see a sign for the motorplex at the bottom of the hill a few kms out from Collie. Turn right. Then it is left at the next tee junction and the circuit is a couple of km's further down on your right.
There is no 98 Octane in Collie. Best bet is to fill up in Pinjarra & also bring a jerry can.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
