  • Replies 227
Posted Images
Actually Winton is ok fun in the rain.
Not as fun as PI though.
Calder and Sandown are TEH GHEY in the rain but Winton is ok.
But as Hung mentioned the forecast for Benalia is better than for Melbourne on Sunday.
Only spewin I'm going to miss the Sandown 500 on Sunday now because as mentioned Sandown is no fun in the wet.
Wet track days are the most fun. Its only a problem when its heavy rain and drainage becomes an issue...aquaplanign sideways off the track into tyres is nto fun...but it normally has to have rained pretty hard and consistant for it to get that bad.
No drama re the signing in...
Maybe i can convince aaron to come in the M5, it has TV :) I'll sell the seats in it to the highest bidder :O
Hey guys.....looks like with all the packing and stuff I'm not going to be able to get outta Melb before around 2-3pm (Troy...zack just won't pull his weight to help with the move LOL)
If anyone else wants to leave around then let me know otherwise I'll see you guys up there B)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
