Had my RB30DET on the dyno today hoping to up the boost to 15psi. Problem is it started to lean out at 12psi and feeding in more duty cycle to the injectors didn't seem to have any effect on the A/F ratio. I have a Bosch 910 pump which should be good for 450-500bhp, 550cc injectors and am using the standard turbo pressure regulator. My tuner thinks the reg is not holding the pressure high enough on boost.
Is this a fair call?
He has suggested a Malpassi, but i remember hearing that the pressure can fluctuate a little with these. Anyone have FIRST HAND experience with this?
https://www.sau.com.au/forums/topic/83123-rb25-turbo-fuel-reg/
Did anyone check the fuel pressure when this happened? It's pretty easy to spot when the pressure stops rising with boost. If the pressure increases and then hits a wall then it's the pump.
My malpassi allows fuel pressure to fluctuate by about 1 psi eachway.
As nismod has stated it is worthwhile running a dedicated power feed to the pump with a relay triggered off the current pump power feed. It also eliminates the fuel pump speed control.
The 910 may be a bit undersized for your application, an 040 intank pump is pushing it at 260rwkw and the 910 is a bit smaller (i think).
We ran out of time to hook up a pressure guage on the day. What i plan to do today is run some compressed air at 12psi into the reg and measure how much fuel is returned. At the same time i'll check the pressure. This should tell me... a) how much fuel the engine can use without the pressure dropping off and B) if the reg is actually working correctly.
Dump_pipe, I bought a R33 DE head for the conversion and changed the reg for an R33 DET unit. Part numbers are definately different. I guess the DE reg dosn't have the rising rate ability that the DET reg has.
do they make direct swap nismo ones to suit?
Yes they do - mine cost 170aud delivered a year ago, very easy to fit too. I've also been told that melpassi's don't hold good steady pressure - haven't had first hand experience though with the melpassis but with the fuel press guage on the dyno my nismo held rock solid fuel pressure with a bosch 044- no flicker at all. But as everyone seems to say you don't need an adjustable reg unless going crazy on power or want to put more rail pressure.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
