My good mate Kel Sweeney did the final tech inspection and the initial inspection was done by Greg Shields in Sydney.
awesome, kel's in cardiff isnt he?
did andra kick you after the 10.3? i expected to get kicked out at drag combat but i didnt get logged or recieve a letter in the mail.
will be good to see two local cars in sport rwd.
Paul and Stacey are UDL'd and TWOOGLE is tech'd. Why on earth would they get booted?
Adrian
Guest two.06l
There are quite a few quick cars in the top 20, 11's just dont cut it these days, although alot of them are one hit wonders.
Which of these cars will be at Jambo?
Yeah this list is only for 10.99 or better....but any fuel or rubber is permitted. for the hpi list go here....
http://www.hpi.com.au/drag_records.php
Good to see that they have finally updated their records page :) Congrats on the 7th spot.
What's with the MPH readings to the poofteenth of a decimal place? :lol:
Guest two.06l
Don't know, we had a bit of a giggle about it too (how was it measured?)
How awesome was Pauly's 60' time
Adrian
a good mate of mine knows paul and stacey and when i told him they had run a 10 he asked me if they got booted as when he saw the car it didnt have a cage, that was why i asked.
i haven't seen the car up close myself
shane
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
