My good mate Kel Sweeney did the final tech inspection and the initial inspection was done by Greg Shields in Sydney.
awesome, kel's in cardiff isnt he?
did andra kick you after the 10.3? i expected to get kicked out at drag combat but i didnt get logged or recieve a letter in the mail.
will be good to see two local cars in sport rwd.
Paul and Stacey are UDL'd and TWOOGLE is tech'd. Why on earth would they get booted?
Adrian
Guest two.06l
There are quite a few quick cars in the top 20, 11's just dont cut it these days, although alot of them are one hit wonders.
Which of these cars will be at Jambo?
Yeah this list is only for 10.99 or better....but any fuel or rubber is permitted. for the hpi list go here....
http://www.hpi.com.au/drag_records.php
Good to see that they have finally updated their records page :) Congrats on the 7th spot.
What's with the MPH readings to the poofteenth of a decimal place? :lol:
Guest two.06l
Don't know, we had a bit of a giggle about it too (how was it measured?)
How awesome was Pauly's 60' time
Adrian
a good mate of mine knows paul and stacey and when i told him they had run a 10 he asked me if they got booted as when he saw the car it didnt have a cage, that was why i asked.
i haven't seen the car up close myself
shane
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
