Say Hello To My New Drift Pig (project)
Rezz
Nice silvia.... respect 2 the 2-tone and respect 2 the brown interior .. gotta love the old school cars. The clear indicators give it a more modern look... i like :)
Edited by Player_Hater
^^^ Thanks guys... I'm starting to feel a bit better about the purchase :D
The front AVS rims are in the mail! Picked the rear rims up for A$60 for the pair!!! :)
Car is looking good now.
What are the the red slash over the plates?
Warning to locals
Gaijin Watch Out :);)
or
He is finally going home
Edited by CircusMonkey
It's a signal to the Yakuza... so they know who's fingers to cut of next :)
Seriously, they're temporary number plates for de-registered cars. I need them because I'm still trying to fit as many cheap Yahoo auction parts as possible... I'm doing well!
So far:
4x Yokohama AVS VS-6 wheels - 10,000 yen
2x Yokohama DNA GP tires (80% tread) - 2,000 yen
1x Silvia 'GT-R' grille - 2,000 yen
2x Tein Adj. Pillowball upper mounts - 4,000 yen
2x clear indicators - 4,000 yen
2x '92 Silvia black mirrors (as new) - 2,000 yen
1x CA18DE air flow meter - 1,000 yen
Total: 25,000 yen (A$300)
^^^ Thats with 4 WHEELS and 2 TIRES.
Needless to say I'm having a ball ;)
chances are it'll never happen as that car's doomed to go to perth :)
LOL... the olde Melbournian 'Perth piss take' on cue... try a bit harder next time hey mang? ;)
^^^ And don't say your not from Melbourne Shan, some Melbourne guys here told me about your AFL footy shorts fetish... :)
My fetishes revolve totally around NRL and union shorts thank you very much. I may live in melbourne, but my sporting tastes are very Sydney based where I grew up.
And I support the Balmain Tiger's if you must know.
I try to avoid Perth pisstakes, other than for the odd business hours, boer water and the horrid heatwaves, its actually a really nice place. What I inferred was that your car and mine will be on totally different sides of the continent.
nice S13 Rezz! looks exactly the same as my previous car, same 2 tone, same brown dash ect... mine also had cup holders above the centre console box (rare factory option?) also beeped when in reverse and at 107kph :lol: was a nice car, i sorta miss it after seeing these pics :D
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
