Hey guys, im new to this form.  I just got my 89 GTR last week, im from Canada.
My 4wd light come on here and there im not sure what the problem is.  Some times it stays off and sometimes it turns on when its on i only have rear wheels working.  Please help.
thanks
Normally on the GTR if one is driving at low speeds and turns the ignition on and off quickly it disengages the 4wd, the light comes on and you are in 2 wd, comming to a stop re engages.I would say that you have a electrical fault , something loose either in ignition or loom to your relay in the box on right inside gaurd in engine bay . Have alook any way , it,s a start .
Failing that down load in PDF the manual which will give you a schematic , which will help you trouble shoot .
Good luck.
Good luck.
I haven't seen the skyline wiring diagram, but with most new cars you can't really trace what operates the lights on the dash as they are usually controlled by a module that controls eleventy billion different other things.
On the GTR's what does the 4wd light indicate? that its engaged or that their is a fault?
If you have a mate with a diagnostic tool it *may* offer some insight to what could be giving problems.
Cheers
Matt
thanks alot guys.
I will check whatever i can, but i do have 2 other friends who have GTR's. Im in Ontario, Canada and there arent many GTR's here so getting help will be a little hard but i have to do my homework and reasearch whatever i can first. In the province of Ontario there are probably around 6 GTR's maybe little more or less. Its very RARE here to have a GTR we could only import cars that are 15 years or older. Anything newer is illegal.
Anyways guys thanks for your help i will check my car tomorrow and see if i still have that 4wd light comming on.
thanks
Fluid low
Low Voltage (alternator or battery problem)
Or just needs a bleed (2 points, 1 at the transfer case the other above the rear diff)
That covers 99% of the problems. The light indicates an error. The ATESSA unit in the boot has a light that will flash a number of times to indicate what it is, so if it is not one of those problems download the R32 workshop manual and check it out.
hey guys
alright so when i turn on the GTR the steering fluid in the trunk goes down to the MIN line so i added fluid when the car is on the the max line. Today i noticed the 4wd light turned back on. Would the 4wd light come on if i turn on the car and movie it right away?? Well thats what i did and i turned the car off and turned it back on and the light never came back on again. Ill get the lines bleeded when i take it to the shop tomorrow.
thanks for your help!
  • 1 year later...
hey guys
did u fix ur problem if so what was it?
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
