I'm about to run these tyres for the first time and was wondering if someone could give me some help with COLD tyre pressures. And what is the optimum HOT pressure i should be aiming for.
I'm running these on my Toyota Supra, i'm asking you guys because the GTR and Supra are around the same weight and would like to save some time chasing the optimum pressure for these tyres.
Thanx :rant:
Mark
Thanx :rant:
Mark
We use these on a GTS-t and maintain 30-32 PSI hot. Start at around 24-25 PSI Cold and adjust from there.
Ian
Which track and how many laps?
Ian do you start with same pressures front and rear left and right? generally you will get 2-3psi extra heat in front v rear and 2-3psi inside v outside tyres. So for example Oran Park if you are aiming for 32 all round maybe start with
RF 25
RR 27
LF 27
LR 29
RF 25
RR 27
LF 27
LR 29
Duncan, yes I start with around 25 psi all round and adjust at the finish of 1st Superprint 3 flat out laps. At EC RF and RR are always higher after running than LF and LR and I adjust all to 31 PSI.
Ian
Dont be worried to much about COLD pressures as long as they are ball park it will be fine . The key is to get to your designated hot pressures asap . Say 38psi is your target ( thats mine for toyo888's) ill start cold at 35psi do my sprint ( 4 laps) and when car returns to pits quickly reset pressures to my target of 38 psi as they have usually gone over this . Ill do this for the next seesion and then find that they are all at my optimal pressure by the third sprint and no need to reset.
adam
32 psi Hot sounds a little low but hey all tyres are different that's why i am asking.
What i'll do then is start at 28 psi cold and work down until i reach about 32psi HOT.
I'm doing a track day at Eastern Creek, 20 min session, 5+ hot laps taking into account warm up and cool down laps, good point about the pressures front to rear and side to side, i'll monitor it and let you guys know.
Thanx again
geeman.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
